Homey must tell a sentence when a window is open and the temperature inside is higher than outside
Hi, I’m a new Homey User.
I want to create a flow and don’t know how to set it up.
Material :
Temperature sensor inside the house
Temperature sensor outside the house
Door sensor
The idea is :
If the door is open and the temperature outside (from the outside temperature sensor) is higher than the temperature inside (from the inside temperature sensor), homey will say a text like “Temperature is to high, please close the door”.
If someone could help me.
Thanks a lot
Guess you gave the answer yourself
First temperature tag in logic is the local tag from the trigger. The second temperature tag is from the living room temperature.
Thanks a lot for your help
Kind regards
