Running out of memory on my Homey Pro so testing SHS and HomeyLink - basically the idea was to offload the WiFi apps on SHS and all devices connect with HomeyLink.
Today my internet went down, I can access HomeyLink Pro locally fine, I can access SHS fine, but all the HomeyLink devices offline. Any ideas?
Are the SHS and Pro on the same network? Can they reach each other correctly? If they can’t connect locally, HomeyLink falls back to the server connection
Yes, all on the same network, Homey Pro ethernet. Only variation though obviously is SHS is in a docker container, network mode host. Just had a thought about that which I’ll look at.
Must be the case, I’m doing some check dns side in case, but maybe just bad luck. Not sure I can trust that, might be the prompt for me to move all the zwave/zigbee to HA as that was fully available for the devices I have there.
