Homey firmeware update 12.4.xx some flow(s) does not work anymore
After every firmware updates starting from 12.4.xx there are every time some flow(s) that do not work. After deleting and rewriting the same flow(s) all is working correctly again.
Restarting Homey has no effect.
Did you investigate?
  • same flows every time?
  • What cards fail?
  • Related to specific apps?
Every time an other flow.
Always a trigger flow (If) till now.
Almost all my items are from Shelly.
Shelly items are up to date .
Shelly app is up to date
Homey is up to date
Are you by any chance using firmware 1.6.x on your Shelly devices?
The developer of the Shelly app for Homey published several updates to the app supporting this new firmware in recent days:
Trigger changed in another trigger and saved.
Then original trigger back and saved, and all is working again.
Doesn’t look like it is an Homey Firmware issue as you confirm you use Shelly and updated that.
@Rein_Blaauw can you confirm it is the Shelly App updates and edit the Topic Title accordingly.
