Homey + Doorbird flow issue for doorbell ring?
I have a rather weird issue… hopefully someone can provide some guidance please
I have a Homey Pro and a Doorbird D1101KV
I’ve setup a flow on the homey so that my Fibaro smart modules turn on lights when the doorbell rings
  • at the entry outside
  • in the hallway inside the house
This is the flow
When…
The doorbell rings (this is the doorbird card)
And…
The Time is between 6:00pm and 4:00AM
Then…
Turn on hallway (Fibaro card)
Turn on Front entry light (Fibaro card)
Turn off hallways after 2mins
Turn off Front entry light after 2 mins
When I use a pin code to enter the house on the doorbird SUCCESS!! the lights come on in the desired places
BUT - If I press the doorbell - lights do not come on :frowning: (defeats the process of turning on lights for anybody ringing the doorbell
What am i doing wrong?
Not sure why it would work for the PIN and not for the doorbell ring.
  1. Do i need to add the Doorbird chime added in Homey - not sure if I can add this? Tried to search for it but Homey wouldn’t find it.
In the flow I also tried replacing the “The doorbell rings” card with the “The generic alarm turned on” and this also didn’t turn the lights on.
Any recommendations would be welcome!
Mcos0544
Show your two flows, because I don’t quite understand what you mean by “when I enter the code”
Hello @Asterix
Here is my flow…
What I mean by entering the code is….
On my doorbird I’ve configured a keypad code so it opens a latch so I can unlock the door
When i enter the keypad code on my doorbird and open the door - Presto Lights come on
When i ring the doorbird doorbell - no lights… :frowning:
This is the other flow i tried with the generic Doorbird alarm. Thought it may work because i have alerts setup on my phone when the doorbell is pressed - so I thought if the alert was generated then lights come on? - didn’t work either.
Does that explain it?
Hopefully you can share some insights as I don’t know what other card i could use as the below are the only ones available.
Regards,
mcos0544
I now understand what you mean.
Please show your complete flow with the code, there must be a difference between the flow with the lights.
What happens if you simplify the flow for testing purposes:
  • WHEN The doorbell rings
  • THEN Turn on the hallway light
Does that work?
@Asterix, apologies I don’t know how to provide the complete flow with the code? If you can explain how i can do this, I can provide.
Tried this simple flow as you requested and the lights do not come on when doorbell is pressed.
1 Did you install the DoorBird phone app?
I ask, because with Eufy doorbells for instance, you have to enable notificatons from within the Eufy phone app, in order to get the doorbell trigger card working in Homey. Else it just doesn’t send any trigger.
Possibly DoorBird uses similar techniques.
2 Does this make any sense (note the notification schedule remark):
  1. Yes i have the Doorbird Phone app on my iphone
  2. I do get critical alerts on my iphone when the doorbell rings but there is no card for this so i can use this as a trigger to turn on the lights.
Any other suggestions?
Regards,
mcos0544
Just like you did with the other flows, just make one or more print screens.
I suspect that you have something else in this flow that works according to your information that you do not have with the other flow💁🏻‍♂️
Hi @Asterix
This is the screen of the full flow, there is nothing more above or below…
This screenshot taken from the Homey Webapp
Still confused why the doorbell doesn’t trigger this flow but entering the pin code does.
Not sure what other options i have
Regards,
mcos0544
Please, send this flow where you entering the pin code. Or is that not a Flow? I mean the flow that works.
You must have a flow that starts similar to this:
WANN: entering the pin code
THEN: turn on light 1 (Is just an example)
Hi @Asterix,
That’s what I mean I don’t have a flow for the pin code at all.
My intent was to automate the lights when the doorbell is rung on the doorbird.
I setup the flow and realised that it only works for the Pinpad entry and doesn’t work for the doorbell.
To add, when added this flow… at the request of @SunBeech
When I enter in the pincode on the Doorbird the hallway lights do turn on.
So it seems that “the doorbell rings” card only triggers successfully when i use the pinpad on the Doorbird.
Is this a bug? can it be fixed? or surely others are using a combination of doorbird with Homey and fibaro switches.
I originally bought the doorbird due to its compatibility with Homey… but what have i uncovered?
Mcos0544
Hi @Asterix,
Would you know if Doorbird uses HTTP calls to Homey to trigger these automations?
By chance I was reviewing my setup in the online Doorbird app and came past this
The image reflects the DHCP IP address for the doorbell for WiFi MAC address
i.e. 1CCAE375B1FB = WIFI Mac Address and 192.168.1.223 is the DHCP IP address
I’m not using WIFI for the Doorbird its connected to a POE switch
Its using the LAN MAC address (different to the above) and a static IP as you can see from previous screengrabs the Doorbird is using 192.168.1.209 (different to the above).
Could this be causing the issues? I’m not confident changing those values just in case i then break the doorbell.
Thoughts?
mcos0544
I think i worked it out… and looks like its working now - WOOHOO!!! :grinning_face:
The schedule was blank for HTTP(S) calls to the Homey doorbell trigger
Is summary it wouldn’t ever trigger the HTTP(S) call when the doorbell was pressed
As soon as I went into expert settings and then schedule for doorbell
I selected HTTP(S) calls for the doorbell trigger and then enabled it for all times (every box colour blue) and now when the doorbell rings the lights turn on…
mcos0544
Perfect, you did it :+1:t3:
I had just suspected that the wrong setting must be in the Doorbird and actually has nothing to do with homey. That’s why I wanted to see the other flow, but you don’t have a flow for the pin entering, but this is done directly via doorbird.
Good to hear that you solved it.
I think @Peter_Kawa was also referring to this schedule in his earlier post in which he linked to the topic with setup instructions.
Thankyou @SunBeech and @Asterix for your input and assistance
Also Thanks to @Robert_K used his response from Problem connecting Doorbird via Doorbird app on Homey - #13 by Robert_K to login to doorbird web portal and discover the solution
Thatxs exactly what I meant, yes. Apparently @mcos0544 did not put it together at first, because
is just the same as what the instructions by the app developer say.
I can’t get my head around why DoorBird shoved the main event, [Doorbell = pushed] under “Expert Settings”…
My expectation from the default settings would be: Doorbell works 24/7, UNLESS user enters a custom schedule…
