Homey suddenly don;t speak anymore…
The orange led ring is coming up, but no sound/ Speach.
I did a PtP for about 10 minutes, it started up with a red ring at the end.
After that everythng at Homey is still working, except the sound from Homey
I did a reset from the system page after that.
Now Homey started up without a redring.
The orange “speach” ledring shows up, but still no speach
Good idea
I did make a flow to turn back volume (Both mainvolume and music volume) to 100%
In de setting page the volume says both 100%
No result, No speach
I did as test add a external speaker and tested again
At speak there was a very soft noise ending with a non stopping very anoing high tone.
Tested.
The same result.
Homey working okay, no speach.
Looks like Homey (speach generator?) is broken.
Or is that software?
Then its strange that external speaker is also not working.
Edit:
I did add, after changing power plug, the external speaker again.
Now I did understand with a hugh amount off noise the tekst.
So there is some difference between the powerplugs?
Must say i never heard the countdown before. And did some recovery’s in the past.
Glad the rest is working normal because the answer to ur mail will not be before monday.
Athom thinks it is a hardware problem.
I did send it to Athom for repair.
Unfortunatly I couldnt find the invoice anymore so it will not be repaired on warranty.
The maximum repair time is two weeks. So I hope it will be returned before christmass.
