Hello, when trying to log into the HCS website, I am receiving the following error message after clicking the ‘Login via Athom’ button. Is this a known issue? Error: {"code":400,"error":"invalid_request","error_description":"A client with the given ID doesn not exist."}
It’s deprecated, Kenneth. I’m not sure why it’s still online… You’d use https://homeycommunity.space instead.
But certain apps can be found @ Github / Bitbucket and you can install them by CLI
Thank you. I have been trying to secure OwnTracks which I finally did but experiencing many rabbit holes trying set it up with AI guidance.
Is this of any use?
‘Location and Presence’ is the new name for the app to use together with the Owntracks phone app:
Thank you Peter. I have been able to get the Location and Presence app installed on Homey Pro, and it should serve my purpose. My only hiccup now is that I am having some trouble setting up the iOS app which apparently must be configured precisely to “coordinate” with Location and Presence on my Homey Pro. With full transparency, I have been relying on AI to guide me through that process and it’s been one rabbit hole after another because the information I’m getting is either out of date or incorrect. With that said, can you point me to some other source that can guide through the steps to create Home and Away routines for my Nest Learning Thermostat using a geofence. I actually have one set up using SmartThings which works quite well, but naturally my objective is to utilize Homey Pro for these types of automations. Again, thank you for reaching out.
YW!
Perhaps this is a clear(er) howto, and it includes ios screenshots, Kenneth (follow the link to view the full post); it’s important to disable the ‘Authentication’ toggle:
Can’t help out with Nest!
