Homey bridge keep loosing conection
I am a very new user of Homey. The installation went well together with the integration of heating cables. After a couple of hours, Homey Bridge loses its connection. I have turned off 5ghz on my router. Any tips?
Hi RSP, welcome.
Here’s a list of do’s and don´ts. It’s aimed at the Pro 2019, but the bridge has an identical Wifi chip:
When you’ve got a wifi mesh network, make sure it can’t hop between AP’s, by band steering, by fiddling with transmit power or by MAC address filtering.
Feel free to ask when someting’s not clear to you.
I am reading all these posts, have tried and done the steps, verified my network configuration but still im getting the offline and reconnected messages over and over again. Im not using wifi and have hardline connection to the router, then moved the connection to my google mesh network hardline. Same issues. I a new homey pro user of a little over a month working my way slowly into everything, but last week it started and is getting worse the guidance is clearly not working so a real technical look at whats going on is needed from a homey support team.
