Homey App not responding
Hello Sinds a few day’s my homey app isn’t wokring any more. I only get
Everything is timeout. Can Someone help me please ?
Have you tried clearing the cookies? Which Homey model do you have, Homey Cloud or Homey Pro? And did anything change in your network?
Hello Sven (i Think)
Problem is with all devices that connect to the homey. (app, web) My Homey is a homey Pro. Nothing on my network changed. But my network setup is a bit different tnah usual.
I have to Vlan IOT and LAN. All My IOT devices are in the IOT vlan including the Homey. The User devices are in the LAN Vlan. Everything worked fine until last week. My Firewall between the Vlan is a Unifi Dream Machine Pro.
Have you tried restarting Homey?
Yes offcourse the first thing to do
Hello, can you make a ping test from the UDM to Homey? Your homey is connected over LAN in the IOT-VLan right? Are there switches between which manage the ports? Can you access Homey from outside (not local network)?
Hello, Yes ping is working. Outside access the same problem. On the Same vlan it is working.
Well when it is working if you are in the same VLan (IOT-VLan) then it seems to be a release / port problem maybe? You must release the devices which are in the other VLan which should have access to your IOT-Vlan…but you wrote this works before and you don’t have change anything?
What you also can do is to disable the Wlan on Homey Pro, if you use LAN you don’t necessarily need it, maybe this has any influence of your problem because i guess each VLAN has her own WLAN…sry but i do not know your network structure and on UNIFI are so many setting especially when you have a structure with VLan`s as well!
