HomeSeer Z-Wave switch issue with Homey
Hi everyone,
I’m new to Homey and could use a bit of help troubleshooting an issue. I’ve searched around and found similar reports, but nothing that has resolved my specific problem so far.
I recently transitioned from HomeSeer to Homey, as I prefer Homey’s user interface. I’m currently using two types of Z-Wave switches:
  • HS-WD100+ (Wall Dimmer)
  • HS-WS100+ (Wall Switch)
The issue lies with the HS-WD100+ dimmers. Adding them to Homey works fine, and I can control them through the app without any problems, on/off and dimming both function. However, the dim level percentage doesn’t seem to display accurately in the app.
The main problem is that when the dimmer is operated physically (via the wall switch), the status in the Homey app does not update. In contrast, the HS-WS100+ switches update their status in the app instantly when used physically.
Here’s what I’ve tried so far:
  • Reviewed the raw Z-Wave configuration parameters from the manual.
  • Updated the dimmers to the latest firmware (5.19), which is reflected in Homey’s device settings.
  • Removed and re-added the devices multiple times, both before and after the firmware update (from 5.17).
  • Searched Google and the Homey Community forums. While I’ve seen similar issues reported across platforms, I haven’t found a working solution.
My current setup:
  • Homey Pro (Early 2023)
  • Homey version: 12.5.0
If anyone has suggestions on what else I can try or where to look next, I’d really appreciate the guidance!
Thanks.
Since I can’t find any app for HomeSeer, you most probably added these devices as generic Homey z-wave device.
Only Athom can help you in this matter:
Report your issues to homey.app/support.
Thanks for the reply, much appreciated.
Did you manage to find a solution for this? I’m considering switching my home system to Homey Pro, but I have a number of Homeseer WD100+ and WS100+ devices.
No unfortunately there is not one. A friend of mine moved to Home Assistant and it was litterly an import and it was up and running no issues. If you have made a large investment in HomeSeer switches, I would stick to HomeSeer or migrate to Home Assistant. Home Assistant is probably the easier test as the costs are low to none.
Hello Everyone
I am strongly considering Homey but I mostly have in-wall switches that I use Wink to control (Z-Wave). The switches are HomeSeer and the GE/Jasco/Embrighton product lines.
I noticed that you were able to add HomeSeer switches to Homey, how did you accomplish this? Did you use the Virtual Devices Experiment?
Thank you
