Homematic IP Cooling
i have installed the Homematic IP App and the connection is working fine. I use the CCU3 to connect my HmIP-BWTH Sensors with the HmIP-FALMOT-C12 and i can change the Temperature from Homey. My Problem now is, that i can also use the underfloor heating for Cooling in the Summer. to use that i have to switch the HmIP-FALMOT-C12 into cooling mode, which i did with a virtual button in the CCU3. Is there a way to display this virtual button in Homey?
May be someone has an idea for that Problem.
Thanks for your help.
Hi Benedikt,
there are several options for virtual devices:
Device Capabilities
Virtual Devices
Homey’s own to enable in the Homey App: Settings/Experiments/Virtual Devices
I hope this helps you …
