Help With a Humidity Flow
i have made one and it don´t work ???
This is the value i use:
When:
Aqara Temp and Humidity=
The Humidity Changes.
And:
Logic =
(Humidity) is greater then (70)
Then:
Lamp off
Lamp on
Lamp off
Lamp on
Lamp off
Lamp on
Lamp off
Lamp on
“it don’t work” isn’t very informative, but you should realize that any actions in the THEN part are started at the same time. It looks like you expect them to be run one after the other (lamp off, wait for the lamp to be turned off, lamp on, wait for the lamp to be turned on, …). That’s not how flows work.
You can add a small delay between each lamp on/off action (press the “Lamp On/Off” card in the flow editor to edit the card, that’s where you can add a delay):
  • lamp off
  • lamp on with a delay of 1 second
  • lamp off with a delay of 2 seconds
  • lamp on with a delay of 3 seconds
Again, because all actions are started at the same time independently, the delay is not relative to the previous card, but relative to the start of the entire THEN part.
Thank you.
i want the lamp to blink when the humidity is to high.
it is normaly round 30-60 (now 47)
this is when my kids shower … so the open the windows
and the level will go down.
when i try my flow with just lamp off … that don´t work.
so i think the problem is in When/And.
U want the flow to work when humidity is above 75 and try to test it when humidity is 47.
Try to set more then 15 to check maybe?
i have try … but i don´t know whats wrong.
Do When + And look like ok.
The Humidity value in AND i try´d THIS FLOW and i try´d AQARA HUMIDITY.
no diffrens.
wrong tag?
No green Arrow.
Sk%C3%A4rmklipp3
if i press test it don´t work.
the sensor works fine. i have now 44,7%
What do the 1 tag in Aqara mean ?
Can u tell us where u found the tag?
im testing diffret triggers.
i have now 50 as a value.
in test i try 60 , 70 , 80 , 90. and 40 . 30 .
but nothing happens. the lamp is on and no green arrows.
And u don’t get the green checkmark, do u get the red cross? Or red exclamation mark?
It’s just a matter of the wrong tag.
Just make sure the name of the sensor in below picture is your’s.
So select the sensor AND select the tag from the same sensor on the right.
U need the tag from the local tags on the top!!
