In this testing, it doesn’t matter which value you specifiy with test, It looks at the actual values (which was 66.5 for this unit at the time of testing).
The way i did it (select the tag from the sensor itself) works fine.
btw, i always select the tag from the sensor i am creating a flow for, then you are always sure you are looking at the correct value.
