Help trying to fix the on off automatic switch
Hi
I got a ACM-2300-HC switch. I have it connected but i am able to switch it by pressing the normal light switch but its not working with homey. When i try to pair them its not doing anything?.
Did i do something wrong?
The empty slot is the blue one from the light its connected directly to te power supply.
It it always good to add the wiring plan you implement.
Does the LED do anything?
Is there power on the brown lines to the physical switch and the KaKu, as they are connected to a black wire?
As @RMB says,
What is your plan?
I can’t get it from the photo and can only assume some things.
is it conform one of the examples in the online Dutch manual? ( https://klikaanklikuit.nl/wp-content/uploads/2023/01/70229_ACM-2300-HC_KAKU_MANUAL-NEW.pdf )
Please read: :warning: :warning: :warning:
  1. Seek Professional Assistance: For complex or high-risk electrical work, always consult a qualified electrician. Attempting to tackle beyond your expertise can be extremely dangerous and could result in irreparable damage.
Hi Dijker,
I did connect it like it should.
And now i saw that i forgot 1 step. And that was the last one.
press the button and activate/send signal.
And now its working, this is really stupid of me.
Thanks for you reply
