I use the Fibaro Smart Implant to open my gates and garage door. Connected to the Input of each device is a magnetic reed switch which sets an alarm when the gates or garage door is opened.
Is there any way to have these alarms monitored by #heimdall ? When creating flows you can see input 1 and input 2 on the device and take action when these inputs are either opened or closed.
Hi @Peter_Bittner,
Should be possible when you link it to a Virtual Device, please see the FAQ
Thanks. Have read the material and gave it a go. The device is visible to Heimdall but I can’t seem to set it’s value.
I have set up the virtual device as a sensor/contact alarm.
I then set up a flow as per below. Where have I gone wrong?
Please follow the instructions to the letter. You need to set the capability (alarm_contact or alarm_motion) to false or true.
Ok, thanks for continuing to help.
I have re read the instructions but when I create the VD I don’t see how to set a capability. I cannot see a tag called “alarm_motion”. I only see a tag called “Motion alarm” in red.
Peter
You have to set the alarm_contact (or alarm_motion) to either false or true in a flow. All relevant screenshots are in the previously mentioned post.
