Heimdall - Let Homey watch over your home
That Popp solar siren looks quite similar to this… I wonder if they are the same device, just being sold under a different brand name (a google search for “Solar Outdoor Siren z-wave” turned this up)
Or a Zigbee option that would work nicely with Homey
Wolf-Guard uses 433 MHz, POPP uses Z-Wave!
I assume that both sirens are not currently supported by Homey.
Perhaps we can discuss the topic of “sirens” in a new thread, since this topic doesn’t belong in this one → OT!
I notice that a sensor important for my alarm system is delayed in reporting the status in Homey when Heimdall is armed en that sensor is set to delayed in Heimdall. Am I correct in concluding that the Heimdall delay is the reason that the Homey status of the sensor is also delayed?
No, that’s not possible. When a delayed sensor is tripped Heimdall just adds a timer and after that expires acts on it.
Thanks. Must be something with the Ikea Matter/thread sensor then,
Cheers, Joop
Continuing the discussion from Heimdall - Let Homey watch over your home:
Hi everyone!
I’m looking for a reliable keypad to arm and disarm my Heimdall alarm system on my Homey pro 2023.
I was considering the Frient Keypad, but since it’s no longer being manufactured, I’m looking for an alternative.
ChatGPT suggested the Ring Alarm Keypad V2 (2nd generation), which should work with Heimdall through the Ring Security app.
Does anyone have experience with this setup? Does it work well and reliably? I don’t own any other Ring products and would prefer not to have to buy a separate Ring system.
Or are there any better alternatives available?
I’d love to hear your experiences! :blush:
I am using the Ring keypad and it works great.
You do not need to by any other Ring devices but the keypad, it connects directly to the Homey.
See Ring Security - Extend Heimdall with Ring Security products
Hi Anders,
Thanks for sharing! Happy to hear this.
Hi @Drako74 I am gonna check this out aswell. what would you prefer Z-wave or zigbee?
The Woolf-Guard one is 433MHz, which Homey Pro can do, and so can Broadlink RM4 Pro (I have an RM4 Pro and it’s an extremely useful bit of kit, can learn the IR or RF remote control of pretty much anything). And 433MHz doesn’t suffer interference from WiFi etc, and being sub GHz travels through walls better. I don’t own either of these outdoor sirens, so I can’t personally vouch for them.
The Zigbee one is apparently compatible with the Tuya app, so should certainly be compatible with Homey, as long as the location outside you intend to install it has plenty of Zigbee router devices permanently powered near by inside, so it has options for routers to connect to. I also noticed that it is capable of being USB powered, which gives options for backup power or if the install location doesn’t get enough sun.
Let us know what you end up using, and how well it works… as others may find that interesting.
Whatever you end up going with, I hope it works well for your setup.
