I have a greenwave node with 6 sockets which is working within Homey.
But i cannot figure out how the power consumption works.
Also i got 7 sockets/devices in Homey (0,1,2,3,4,5,6) but there are only 6.
Then the power consumption, only socket 1 and 2 give any power measurements, the other 4 display 0
usage, even when i plug in a heater which absolutely uses a lot of power.
When i plugin only 1 device (a heater) in the node in sock 3, 4,5 or 6) and turn it on it has 0 consumption on the chosen port, but when I look at socket 1 then there is consumption displayed, also on socket 2 but this seems always to be around 1.6 watt.
This behavior also occurs using sockets 3,4,5 and 6.
When i plug the heater in port 1 then is chose consumption, but also on socket 2 (1.6 watt). When i plug it in socket 2 i get a rather normal consumption, but this is a little bit less then what socket 1 displays (this all is only with 1 devices connected).
Is this a setting or is my power node simply defected?
