hi
is it possible to install https://github.com/mruiter/com.dresden on my homey somehow?
Try this link.
thanks
I will try this in the evening
worked for me
Although I had to try 4-5 Times to add the Lightstrips, got simple error not adding them, but after retrying, they were added
Now all my Dresden Elektronik FLS-PP3 are available in Homey
The app should be published to the store.
regards adem
hello… were is the link for downloadd app.zip? i don’t want find the link…
Then we cannot tell u because when we do u WILL find the link and u don’t want to. ![]()
But serious, which link ur looking for?
Not the link from first post do u?
this worked for me, it is a fork of the first posted link.
To use athom-cli you have to install the requirements also, see:
https://apps.developer.athom.com/tutorial-Getting%20Started.html
For my centos to install nodejs, I used:
Then:
git clone https://github.com/ChrisBrandhorst/com.dresden
cd com.dresden
athom login
run without installing it: athom app run
or
run with installing it: athom app install
Thanks
after testing the app. the implementation is not fulfilled. the rgb receiver, fls-pp3 is a rgbw receiver, it should have 2 switches like in the homee app or on Philips hub.
turn off white turn on rgb or both…
