I’m using an application called Blynk to control some parts of my home automation. I would like to pull a temperature and humidity value periodically from Homey via a simple webhook (http://docs.blynk.cc/#widgets-other-webhook), is this possible\easy?
I’m using a Xiaomi Aqara Temperature sensor via the Xiaomi Mi ZigBee App.
Why not put the temperature value in a Better Logic variable and use the Better Logic API to retrieve it. It’s all described in the read me from Better Logic in the app store.
