I have installed an Intergas Gateway V3.
It works fine on the iPhone and iPad.
When I try to install it on the Homey, I get the message “pairsession_not_found”
This happens when you switch apps on your phone, for example to get your password from a password manager. When you switch apps, the pair session expires. Make sure you have everything you need on your clipboard before you start the pairing
Plesse find yourself a v2 model to connect it to Homey.
In the meantime, someone reverse-engineered the Intergas phone app to get the v3 GW to work with Home Assistant using the Intergas cloud connection.
So, alternatively, an easy (and quickest) way is to add Home Assistant to the mix.
You can request for Homey support per Intergas Incomfort app topic,
or maybe @smarthomesven is seeing possibilities for a separate Intergas GW v3 app.
@Dijker i think this is posted in the wrong language section.
moved to English catégory
One of those bugs in Homey that has existed for many years now and which Athom doesn’t care about. Yet it seriously degrades the UX.
I think it’s not very easy to fix without breaking existing apps, since the whole pairing process was designed around those “pair sessions”. So if they would remove those, all existing apps would need to be changed
It’s not an issue with pair sessions as a concept, it’s an issue with the mobile app. It should be able to pick up an existing session when it gets lost.
My guess is that the app uses a WebSocket connection that gets disconnected when a user switching to another app, and when switching back to the Homey app it doesn’t reestablish the connection (properly) again. There are plenty of ways around that, and the Homey app is the only one I know that cannot handle a user switching to another app for something like password retrieval.
That’s not the case. The app sends a heartbeat request for that pair session every few seconds, and in the background it probably doesn’t send that anymore.
Google Home can’t handle this either. It closes the oauth dialog when I get my 2fa code for Philips Hue, or when I get my password from a password manager
You could make the interval between heartbeats longer, but when the connection drops or you force-close the mobile app, it will show the error “Another pair session is already active” for a longer period.
That’s how most mobile platforms work, and there are plenty of ways to work around that. But like I said, Athom doesn’t care. This issue dates back to at least 7 or 8 years ago.
Hi Wil,
The Homey Intergas app has been updated today! This should make the app communicate directly with Intergas cloud systems, in case you use Gateway v3 and up.
When adding the Intergas device, make sure to select the “Intergas Cloud” device.
