Gardena what is needed?
Hi Nils,
I think it’s because Gardena uses a closed wireless system? Like tado°, Somfy io and such
Sometimes things are technically not possible, or the manufacturers don’t want you to use other sytems to control their products.
I’d suggest you write to
It’s a pity Homey can’t ‘just’ connect to devices like your smartphone can.
BUT the Bluetooth range is up to 5 meters, like Arie stated already, seems to me pretty useless for garden tools imho.
I kinda doubt that … as you state, it ues Ble which is supported by Homey. The only “closed” thing could be the signals they use. Wouldn’t it be possible to get these signals through reverse engineering the app or intercepting the signal with something like a programm or device listening on the frequency, like a man in the middle attack?
I am pretty sure other devices which work with Homey w/o a hub also were not planned to work with Homey out of the box but manufacturers want to sell hubs, too …
Oh and yes, I contacted support indeed :wink:
Furthermore: Just did some research and found some very interesting things:
A pdf of a presentation that deals with legal issues due to the fact that the software is open source. The pdf aso gives details on the hardware and also where to find the code:
Github site of the code, as far as it is open source:
Another Github site that deals with Home Assistand integration:
And anoher one that deals with “iobroker”, thedescription says one can crete an alternatve app that can be used side by side to the Gardena app:
I am not an expert, but this looks like there’s enough information to create a working app for Homey to avoid the requirement of a hub.
[EDIT]: And yet another project in Python: GitHub - py-smart-gardena/py-smart-gardena: Python library to interact with gardena systems
That’s interesting indeed, pass it on to support I would suggest.
Did you solve this? I got the same problem. So at the moment gardena runs the scheduling, not homey :disappointed:
I’m brand new to Homey and am just having a play round to see which of my smart home devices I can use with the system.
I’ve got a gardena watering system (soil sensor and water controller with gateway) which has added to Homey with no problems.
The issue I have is when I try and use the sensor in an advanced flow. I’d like to do the following:
At 08:00 check the water humidity and if >60% water for 1 minute and if <60% water for 10 minutes. For some reason I don’t seem to be able to use the sensor as an “And…” card (after the time trigger), only a “When…” card. I’m not sure this will work properly as it looks like it will only trigger as the sensor passes 60% humidity, rather than being something I can check at a set time every day.
Am I doing something wrong?
The AND cards are mostly available as a Logics card, where one can use the value tag of the sensor (or anything else).
But on Homey it’s imho easier to turn it around. Make the time a condition, and make the humidity a trigger
thanks for the really helpful reply @Peter_Kawa
I’m so new I hadn’t yet worked out the logic tests but it all makes sense now.
I’ve managed to get it working, only issue I have now is the one which was flagged a couple of years ago - the Gardena system turns on for just 1 minute then shuts itself off, the timer in my flow doesn’t make any difference.
Has anyone managed to get this irrigation system watering for the correct amount of time?
YW!
Can you share the Gardena flow? Or did you refer to a bug by
Yes, it was a bug that @Gerben_Zomer referred to here:
But I worked it out - for some reason you have to go into the device settings for the controller (within Homey) and set a default length of time for watering, provided this is longer than you’d ever want to water for you can then use the delays in Flow to turn off after the appropriate amount of time. For example I set the watering time to 60 minutes, this means that if I just turn it on it will do a full hour but if I use a delay at, say, 10 minutes it will shut off.
I’m afraid I can’t see how to share the flow but will try and work that out too!
hello everyone, why do you use Gardena? While there are cheaper alternative solutions.
can someone help me with my problem?
I have 5 zones that work perfectly with and I control them all with homey. I can’t use the Gardena app because of my pump that is switched on and off via the homey (smart switch).
But now I want to try to use the gardena app instead. Why? because of the functionality of the app. Then I can stop watering when there comes heavy rain ore water more when there is a lot of sun coming. This all is very easy when is it all taken care of by gardena.
The problem is that I can not get the valves and pomp work seamlessly with each other. Probably because there is no ‘’ if ‘’ button when making a flow.
Is maybe someone smart enough to help me with my problem, and knows a work around when gardena does not have a ‘’ if ‘’ button.
@Arnoud_Fleer You can use the Watch/Listener When-flowcards from the Device Capabilities app to create When cards for devices/apps that do not have those flowcards.
Which When card are you looking for?
Note the available cards differ when you look up your flow cards via your device.
Try looking them up via the app in the left column
When you use a non-gardena soil sensor f.i., you should use the When cards of that sensor instead.
Hi everyone;
I want to integrate Gardena devices into my Homey Pro but once the permissions are activated for the Husqvarna Group account, I get the message “404 not found”.
What exactly do we need to do from the Husqvarna portal for Gardena device integration?
Can you help me with this integration please?
Thank you in advance for your help.
Doud
You should contact the app developer (Athom), it sounds like there were backend changes and the “official” app wasn’t updated accordingly.
I have the same problem as well. :frowning:
Did you contact support?
Yes I contacted the support and they told me they are working on it.
“Thank you for your reply and sending the clear video.
Our development team is currently investigating the issue to see why this is happening. Once I receive an update from them I will immediately contact you again.
We apologize for the inconvenience.
I wish you a great day.
Best Regards,
Dorean
Athom Support”.
Good day.
I’m having the same issue, so looks like Husquarva isn’t exactly prioritizing Homey.
