Garden lighting with scenes from Homey: in-lite via Matter, or which system can do it?
Hi all,
We’re about to invest in garden lighting for a large garden (~800 m²) and I want to settle one hard requirement before we commit to a system.
Setup
  • Homey Pro (2023) on Ethernet, the heart of our home automation
  • Planned: in-lite 12V garden lighting with SMART HUB(s) + SMART BRIDGE, linked to Homey via Matter
What I’ve found so far
  • Via Matter the SMART BRIDGE shows up in Homey as one device per lighting group, on/off only (source)
  • Individual lights, dim levels and in-lite scenes don’t seem to come through to Homey
The must-have scenario
When we get into the jacuzzi, Homey (button, sensor or flow) starts a “Jacuzzi” scene that:
  • dims lights at specific spots for privacy, across several zones/groups
  • sets each light to its own dim level
  • starts certain effects
A second scene (“Garden evening”) turns everything back. Routines/schedules don’t need to be in Homey; the in-lite app can keep doing those. Starting scenes from Homey is the must.
Questions
  1. Has anyone managed to start in-lite app scenes from Homey (Matter or a workaround)? Or do in-lite SMART lights (dimmable/colour) show up individually in Homey via Matter, so I can rebuild the scene in Homey?
  2. Does anyone know if in-lite plans to expose scenes or individual lights via Matter?
  3. If in-lite can’t do this: which outdoor lighting system DOES give you scenes or individual dimming from Homey, at garden scale and with quality fittings? Think Philips Hue Outdoor, Casambi-based fittings, Zigbee/DALI dimmers per group, or other brands (Lightpro, Techmar, …). Real-life experience much appreciated.
We’ll only invest in the base installation if this works, so any experience or advice is very welcome.
Thanks!
Nick
Philips Hue does have scenes and individual dimming. With Hue, you can create scenes in the Hue app and also start them from Homey. By creating the scenes in Hue, you only need 1 Flowcard to start the scene for all garden lights (if you have the Hue bridge, which I would highly recommend)
Small update for anyone landing here with the same question. I got in touch with in-lite directly, and here is how it actually works with Homey over Matter:
  • The SMART BRIDGE connects to your router by Ethernet and exposes the in-lite system as a Matter bridge, so Homey talks to it over your LAN.
  • Between the Bridge and the fixtures, in-lite uses its own 2.4GHz mesh, not the 12V cable and not plain Bluetooth. The 12V cable only carries power and does on/off per cable line for non-smart fixtures.
  • For in-lite SMART fixtures you get per-lamp control in Homey over Matter: on/off, dim, color, and a separate warm-white/CCT slider.
  • One limitation: in-lite’s own app “scenes” cannot be invoked over Matter. You recreate them as Homey Flows instead (setting the lamps directly), which works fine.
So: individual dim + color per smart fixture works, whole-group on/off for the non-smart ones, and scenes via Flows. Hope this saves someone the back-and-forth.
