Garage door open / close with liftmaster remote D-66793 443,92 Mhz
Is there someone who knows how to connect a liftmaster remote to open a garage door.
thank you in advance,
Ronald
Ronald, did you solve it?
No still no solution. I’m now Looking for a fibaro module.
I was successful with the Fibaro Relay Switch, connected to the door button wires from the Liftmaster. Works fine.
The challenge is to know if the door is open or closed. I added a PHILIO 4-IN-1 MULTISENSOR with door magnet, but it does not always work.
The fibaro relay connection is one alternative. But when the liftmaster engine already communicate with the remote on 433mhz band it would be nice to connect it to homey directly.
Connect to a z-wave relay feels expensive and unnecessary when you got 3 liftmaster engines like i do
If you want cheaper and more channel devices, you can look at the Shelly and the Sonof 4 channel devices.
Maybe, but my remote is this one TX4EVF
and it’s on 868 MHZ.
Homey will need to integrate with specific Liftmaster bi-directional radio, rolling code on both 433 and 868 MHZ.
Can this be done?
By the way, there are standalone solutions in the market to remotely operate garage doors, independent of brand
These solutions often come with Google assistant, IFTTT integration.
IFTTT is not my favourite, but could be used to integrate with Homey, if really more functionality is needed.
Cost is about $70-100.
Did anyone figure this out?
I bought the Liftmaster 828EV Internet Gateway.
It works very stable with the MyQ app and sends a wireless signal to the garage door.
The MyQ app gives you the exact state, multiple users and custom notifications.
You wire it with an ethernet cable to your router.
It was the easiest way after I spent way too much time trying to DIY integrate.
The only thing I did do (but never use) with Homey is to trigger door open/close using a Fibaro relay which I wired with 2 wires to a wireless button (“Wireless Wall Control 2 Channel”) which then sends a wireless signal to the garage door, but I cannot see the state…
Didn’t I read that MyQ shut down the api, so it would no longer work?
Correct, there’s no MyQ app in Homey. Only a MyQ app on your phone.
What I did was to wire the button that sends a radio signal to the garage door.
I opened the button cover and connected the Fibaro relay. That way I can simulate pressing the button by activating the relay in Homey.
