Hi everyone, is there anybody who had connect a remote control for garage opener, Pulsar RTS 2CH to your Homey? It’s an Wisinovski garagedoor and powered by SomFy. It is 433 MHz what I can see.
Morgan
Morgan
Do you use a conexxoon or Tahoma Box which give you extra possibilities. You also can try the Somfy app and try to ad it as Remote(just trying a few of their remotes, probably one will work. Suc6
No, get it yesterday day and try to find out if it’s possible to connect it directly to the Homey.
Morgan
And I have looked at the SomFy app but it didn’t get it work together. Explain more: I’ll get in to the Homey but it ain’t remote anything.
Thanks, I’ve tried but I ain’t work. I even tried with the other solution remote the window blinds and don’t work. I’ll get them as an icon in the homey but no reactions when I try to rise or lower the garage door.
And you did try to pair the device, by pushing the pair button
Any update on this? I have the same remote, and i wonder which Somfy device i need to get it into homey, Tahoma or Connexxon?
Thanks
