FutureHome Charger - Homey-Bridge
I’m trying the connect the FutureHome charger to Homey Bridge.
I have deleted the charger (and all other devices) in the FutureHome app. And I have deleted my FutureHome account.
I’m able to connect to the charger with blue tooth, but I get a communication error when I try to set it in paring mode. Did read on the forum that the charger needs to be reset by turning of the power.
My charger is connected in the electricity intake cabinet (inntaksskap). So I’m a bit unsure how to turn of the power. But think I have found the switch, can anyone confirm it is the correct one from the picture (at least most likely that it is that one) ?
(can of cause take all the power to the house, but don’t want to if I can avoid it)
here is a picture of all the switches
This is a 3phase circuit breaker.
So could be the charger (but also ovens and cooking plates can be 3phase).
Is your charger a 20kw or 11kw? That would require a breaker like this.
If your charger is lower power its unlikely this breaker is for you charger.
Call manufacturer / installer, or search for the installation manual?
The utility box usually don’t have a metal plate as cover. I’ve never seen this.
I think TS should call a professional.
What could go wrong if you turn it off? Just turn it off and see what happens. If the charger is still powered then turn it back on again and try another one.
Agreed, this is propbably not a location in the NL.
But it is definitely a circuit braker inthere…
Yes there is !
