Hi
I’d like to install a garage opener by Shelly. I use Homekit to control my Homey. Is it possible to force homekit to see this shelly as gate opener and assign a proper, nice, icon instead of normal switch?
Sure but how will I see it in Homekit? as a switch or garage door?
That’s up to you… you can make a virtual device and present it as whatever you prefer
can you help me create this as a virtual device? I see only “light fan or switch” in Homekit app
If you use the Homeykit app, you’re out of luck: it doesn’t support garage door opener devices.
I use Expermient Homey. It works well, but I want to be able to choose something more for Virtual Device than switch light fan.
@Hannes85 i’ve tried also with Virtual Device experiment, still only 3 opitons.
You need the virtual device app, not the experiment.
hello,
the possibility to assign a custom icon should be a native feature in homey, mabe @robertklep in the future will continue tondevelop homeykit?
severall time i wrote to the homey support, nothing, meanwile apple has a lot of new categories of devices. with the experimental honekit interface my fibaro rollershuter in homekit are shown as 2 switches!!! reported to homey a half year ago…
a homebridge homey app would be the best solutions.
best regards
philipp
can you elaborate on homebridge home? will it fix my problem?
He won’t.
Also, you can’t assign any icons in Homekit, but I think what you mean is the ability to control which type of Homekit device a Homey device will be exposed as. That will be quite difficult, because Homekit has a rigid set of device types that have a rigid set of capabilities. So you couldn’t assign a device type “garage door opener” to a Homey device if that device doesn’t have the required capabilities needed for that device type.
OH, that’s a bummer… So I am forced to have switches for gates and so on.
Which virtual device did you use to support the Garage door opener? I could not find any within the virtual app.
Hi!
I have to do one step back and echo @robertklep;
It depends on the actionable items that you present to HomeKit. HomeKit then decides what it can be used for. The screenshots from my earlier posts are contact sensors which simply show a on/off (non-actionable). HomeKit translates this to doors/windows and their accompanying icons.
If you present a item that allows you to slide up and down to open or close, it presents it as window coverings/ sunshades. A simple on/off button itself will only have the 3 capabilities that were discussed before by the topic owner.
@Hannes85, can you please let me know which device type and action type you picked in VD in order to present it to HomeKit as a garage door like in the iOS screenshots you posted above?
But how do you create specifically a “contact sensor” in VD app on Homey? I can’t find that option.
If I select device class type as sensor then function as door/window, it doesn’t show up in HomeKit. I’ve tried basically every device class in VD and almost all functions per device class but I could not get what you showed me in the screenshot you sent
So the contact sensor that I showed in this example is not a virtual device, it’s a Aqara contact sensor (non-actionable) that is presented to HomeKit through the Homeykit app. I don’t have contact sensors that I need to first create a virtual device for before presenting it to HomeKit. Also, there is no way to present a actionable (virtual) device to HomeKit and let it show up as garage door.
