I connected an ESP32 system of my realization to homey to read and set PWM fan speed values. The ESP32 is connected using MQTT Broker to homey.
I’m using a Flow to set a value to the MQTT Topic using a Tag. I use an homey script to do the job and seems that the Flow itself is adding a white space between the name of the topic and the value I set.
I have a Virtual Device (Dimmer) that I intercept the value in the script and create a Tag from script to be sent as value to the topic.
Topic is fan/setSpeed and values are between 0 to 4 based on the value of the dim capability. The script set a Tag named RetSpeed with the value and publish to the topic.
I made a tcpdump of the value and I see that a white space is inserted between the topic and the value.
************** TCPDUMP OUTPUT **********************
01:35:07.746899 IP (tos 0x0, ttl 64, id 1580, offset 0, flags [DF], proto TCP (6), length 70)
192.168.30.211.1883 > 192.168.30.207.54143: Flags [P.], cksum 0x337c (correct), seq 31255:31273, ack 47, win 453, options [nop,nop,TS val 630292761 ecr 2941428222], length 18
0x0000: 4500 0046 062c 4000 4006 7593 c0a8 1ed3 E…F.,@.@.u…
0x0010: c0a8 1ecf 075b d37f 065f 6f1c f367 6451 …[…_o…gdQ
0x0020: 8018 01c5 337c 0000 0101 080a 2591 8119 …3|…%…
0x0030: af52 a1fe 3010 000c 6661 6e2f 7365 7453 .R…0…fan/setS
0x0040: 7065 6564 2034 peed.4
As you can see there is a space (hex char 20) between the topic fan/setSpeed and the value 4.
This is the script I’m using:
var floatSpeed = parseFloat(args[0]);
var setSpeed = 4;
var speed=256*floatSpeed;
if(speed==0){
var setSpeed=0;
if(speed>0 && speed<=62) {
var setSpeed=1;
if(speed>=63 && speed<=126) {
var setSpeed=2;
if(speed>=127 && speed<=191) {
var setSpeed=3;
if(speed>=192 && speed<=255) {
var setSpeed=4;
await setTagValue(“RetSpeed”, {type: “number”, title: “RetSpeed”}, setSpeed);
return true;
If I set the value manually not using the Tag in the flow the value is correct. Even if I set it using an MQTT Explorer to publish the value it is correct. It is wrong only when I use the Flow.
Any suggestions?
Thank you in advance
Bye
Marcello
