I created a flow for my Samsung Smart TV. This flow is meant to turn the TV off in the event it is turned on between 6am and 2pm. This (of course) to regulate the time my children spend on watching TV. The cards are:
If: [TV] Samsung q6 series is turned on
And: Time is between 6:00 and 14:00
Then: [TV] Samsung q6 series Turn off.
The flow works but after a minute or so the TV switches on again, which triggers the flow to turn it off again. Somehow a loop is created. Any ideas on how to fix this?
Sometimes it goes to fast.
Maybe the TV is in a booting-process and it is not finished before you send the switch-off command.
I should try to set a 2 minutes delay on the switch-off card.
There might be something connected to the TV that is turning it on.
For me it was my nvidia shield through CEC.
But since I’m using harmony, I turned off all CEC control and that worked for me.
I tried the following to determine whether it’s the TV or the Homey. I turned on the TV and waited until the flow turned the TV off. Immediately after I disconnected the power of the Homey to see what would happen…the TV remained off. My conclusion is that the problem is within Homey and not within the TV (or the KPN settop box). Next step for me is contacting the builder of the Samsung smart tv app…
The app checks constantly if the TV is on / off, by accessing the TV-interface.
The TV-interface is also turned off when the TV is turned off, but after a delay. On my TV this is about 20 seconds. And sometimes the interface turns on, even if the TV is actually off.
So it is not easy for the app to know correctly if the TV is actually on or off.
The best solution for you might be to use a smart plug to turn the power completely off for the TV in the period.
