Flow cards that I used previously disappeared ?!
Hi all,
As a relatively new used, I’m currently busy creating flows. However, several flow options that I’ve used previously, can’t be found anymore.
One example is the following: Previously under “AND” and “PRESENCE” I could select someone is at home:
But now, that card is missing:
and I can only select when nobody is at home. under “AND” and “PRESENCE”
Am I overseeing something? Or what is going on here? I can’t even rebuild the same flow anymore.
I have similar issues with logic flows.
I hope I’m overlooking something, as it’s quite hard to build the proper flows when cards are missing.
Thanks for taking the time to read this topci & to hopefully help!
Select “some body is at home” and click the option “revert”.
