[Firmware 12.2.0] New device capabilities and changes custom capability priority
The next firmware will add a bunch of new capabilities. Seems like a lot of them are also in preparation for robot vacuums and heat pumps (which are some not yet supported Matter device classes).
Also with those new capabilities there comes a change in how they are prioritized:
Starting from version 12.2.0, Homey Pro (Early) 2023 will shift its approach to favour custom capabilities over system capabilities, aligning with the behaviour already seen in Homey Pro 2016-2019.
Currently, when a custom capability on Homey Pro (Early) 2023 shares an ID with a system capability, system Flow cards are generated for that device. However, with the upcoming change, these Flow cards will no longer be available.
To ensure that existing Flows continue to work seamlessly, apps that use system IDs for custom capabilities will need to update their drivers. There are two ways to make sure nothing in your app breaks. The easiest way is to remove your custom capability from your .homeycompose. This will instead make Homey use the system capability and generate the system Flow cards.
All new capabilities:
  • alarm_bin_full
  • alarm_bin_missing
  • alarm_cleaning_pad_missing
  • alarm_cold
  • alarm_connectivity
  • alarm_door_fault
  • alarm_gas
  • alarm_light
  • alarm_lost
  • alarm_moisture
  • alarm_noise
  • alarm_occupancy
  • alarm_pm01
  • alarm_pm1
  • alarm_pm10
  • alarm_power
  • alarm_presence
  • alarm_problem
  • alarm
  • alarm
  • alarm_running
  • alarm_safety
  • alarm_stuck
  • alarm_tank_empty
  • alarm_tank_missing
  • alarm_tank_open
  • alarm_vibration
  • audio_output
  • battery_charging_state
  • dishwasher_program
  • docked
  • fan_mode
  • fan_speed
  • heater_operation_mode
  • measure_hepa_filter
  • hot_water_mode
  • laundry_washer_cycles
  • laundry_washer_program
  • laundry_washer_speed
  • level_aqi
  • level_carbon_filter
  • level_ch2o
  • level_co
  • level_co2
  • level_nox
  • level_o3
  • level_pm1
  • level_pm01
  • level_pm10
  • level_pm25
  • level_radon
  • level_so2
  • level_tvoc
  • measure_aqi
  • measure_carbon_filter
  • measure_ch2o
  • measure_content_volume
  • measure_data_rate
  • measure_data_size
  • measure_distance
  • measure_frequency
  • level_hepa_filter
  • measure_monetary
  • measure_nox
  • measure_o3
  • measure_odor
  • measure_ph
  • measure_pm1
  • measure_pm01
  • measure_pm10
  • measure_radon
  • measure_rain_intensity
  • measure_rotation
  • measure_signal_strength
  • measure_so2
  • measure_speed
  • measure_tvoc
  • measure_tvoc_index
  • measure_weight
  • media_input
  • mower_state
  • operational_state
  • oscillating
  • pump_mode
  • pump_setpoint
  • refrigerator_mode
  • speaker_stop
  • swing_mode
  • target_humidity_max
  • target_humidity_min
  • target_humidity
  • target_temperature_level
  • target_temperature_max
  • target_temperature_min
  • vacuumcleaner_job_mode
  • valve_position
YM “LG device types” :face_with_peeking_eye:
