I’m building a heating controller for a ESP8266 based room thermostat and wallheating controller which I have build. I’m using Homeyduino for the communication between Homey and the device. Because each controller can manage the temperature in multiple rooms, I originally planned to use sub capabilities. That does not realy work on Homeyduino however. So in the end I decided to create sub cababilities for things like measure_temperature an target_temperature. The capabilities do shwo up in the the Homey app, and I can change them etc. The problem is that they are not available in flows. I have off course read all documentation that Homey provides, but that is really quite limited, so any help would be appreciated.
So far I have defined te capabilities in app.json under capabilities
"capabilities": {
"thermostat_mode_0": {
"type": "enum",
"title": {
"en": "Thermostat mode 0",
"nl": "Thermostaat modus 0",
"de": "Thermostat-Modus 0",
"fr": "Mode thermostat 0"
"desc": {
"en": "Mode of the thermostat",
"nl": "Modus van de thermostaat",
"de": "Modus des Thermostates",
"fr": "Mode du thermostat"
"values": [
"id": "0",
"title": {
"en": "Active",
"nl": "Aktief",
"de": "Aktive",
"fr": "Active"
"id": "1",
"title": {
"en": "Inactive",
"nl": "Niet Aktive",
"de": "Nicht Aktive",
"fr": "Inactive"
"id": "2",
"title": {
"en": "Away",
"nl": "Niet Aanwezig",
"de": "Abwesend",
"fr": "Ne pas la :-)"
"getable": true,
"setable": true,
"uiComponent": "picker"
I have also added the new capabilities to the drriver capabilties in app.json
"drivers": [
"capabilities": [
"thermostat_mode_0", "thermostat_mode_1", "thermostat_mode_2",
"measure_temperature_0", "measure_temperature_1", "measure_temperature_2",
"target_temperature_0", "target_temperature_1", "target_temperature_2"
I has expected that that would be enough and that homey would automatiucally created flow cards for these capabilutes, what am I missing?
