Fibaro Smart Implant - Direct Association?
Hi!
I need some help with Direct Association.
I’m using it with a few buttons to control relays, and it seems to work fine, although with 500ms-1s with delay.
Anyways, I’m trying to activate the two output relays on the Fibaro Smart Implant using a Z-wave switch and direct association.
How do I know what inputs the Smart Implant is expecting? Its node ID is 27, so I would assume it’s 27.1 and 27.2 for the relays, but where do I find this documentation?
I guess I’m not sure how to read the manual on this, only what associations are supported from the Smart Implant, while I want it to be on the receiving side.
Did you find out if .1 and .2 are the correct values to use? I’m trying to make a direct association from a Shelly Wave I4 to a Fibaro Smart Implant, but I can’t get it to work. Not really sure what the problem is.
