This is an older version of the door/window sensor with an input connection inside the unit. I want to use this input to connect to an old school door push button.
I included the Fibaro, it shows up in Homey correctly but no alarms show. Not the door contact nor the sabotage alarm. I must add that the plastic clip on the back of the sensor is missing. This clip presses the button inside the sensors, once mounted to a wall/door.
I reset the Fibaro. Still no alarms.
Any suggestions?
