I have made a flow that when I turn on Fibaro dimmer, other lights in the room will turn on. It works only in the app, not the physic switch.
Any idea?
Any idea?
When you flip the physical switch does status for the light update in the app?
No,it doesn’t update in the app.
It looks like you do not get a trigger from the psysical switch and since the app can control it everything’s fine except for this.
Do you have a momentary switch or a toggle? Is parameter 20 set accordingly in the Fibaro?
Is the Fibaro triggers wired correctly according to the type of switch and setup you have?
Please check those above.
I have a toogle switch. I had an another system before Homey, everything worked fine there.
So the parameters should be like this, 20,2,255?
If it has worked in the past and you have paired it correctly with Homey’s Fibaro app it should work right away.
I’m curious to know how you paired this deviced with Homey. Did you pair it using the Fibaro app? Have you tried to unpair and redo the pairing?
Input type can be set via advanced settings of this device, this setting can be reset when you have the device coupled to your Homey
(your image can be different, this is from a qubino switch)
