Fibaro app turns wall plug on
I have a fibaro wallplug wich switches a floorheat pump on and off through some flows.
When i test the flow the pomp should turn off, it actualy does for .1 seconds then get turned on again by the fibaro app.
When i manualy try to turn it off, the fibaro app turns it on again. Settings should be correct.
Where can i see why fibaro is turning the wallplug on again?
In the Advanced Settings there is a “Alway On” setting that shall be Off. I see in your picture it is Off, but maybe it helps to set it to On and save it, then to Off and save it. As it looks it behaves as if this parameter is set to On.
This worked, thank you :slight_smile:
Is there a reason this happend or is it a random bug?
This is typically for computers :grinning_face_with_smiling_eyes:, using the procedure above I make sure the setting is as shown. Something simulator like switching a computer off and on again.
