My changes of my Fibaro devices in advanced settings are not saved.
Don’t know if it is a problem of Homey 2.0 beta or the beta app of Fibaro.
Please advise.
Kind regards,
Robert
Please advise.
Kind regards,
Robert
Battery-devices, mains-powered, both?
Battery devices, motion and smoke detectors.
Battery devices only receive their settings at wake-up. This is usually only after several hours or even days.
If you want to save immediately you have to wake up the device (clicking the button 3 times for Fibaro) and then press Save.
You’ll see that you receive a different response when saving then.
No the procedure does not work, the Homey app error message is: Settings cannot be saved, timed out after 30000ms.
Ah, would have been nice to mention that in your first post
So it’s working ok for powered devices?
Might be a bug then indeed.
Tried the procedure after your reply, so how could I have known…
Do not have powered devices.
Suddenly its now saving the settings…
Oh @Fire69 you saved me with your answer !
Now I can have temperature every minute with motion sensors
Thanks again !
Weird… No more time-outs?
Keep in mind, that will be bad for your battery life
Key have the Keyfob working fine and its fast for the time being.
Yet. I want to enable double and triple clicks on a button. So I go do the device advanced setting. Change the setting for a button to 1x,2x,3x, long (say for a square), click on save and it times out.
Here is a video:
Thanks in advance for any help.
Had this same problem after just pairing the Keyfob. I resolved this issue by restarting the Keyfob app in Homey. To do this, in the Homey app, go to ‘More’ -> ‘Apps’ -> ‘Fibaro’ -> the options/gear button in the upper right corner -> ‘Restart app’. Now you should be able to change the settings.
Usually, that is not how it works. A device has to be awake to receive new settings and a restart from an app normally doesn’t trigger a wake up of a device. Also, most battery devices have a setting for waking up after a specified time period, but even that is not enough to receive updates with a delay.
You must (almost) always wake up a device manually (mostly by pressing a button once or 3 times) just before sending the new settings to it.
