I have a Homey Pro 2023. I am replacing some Nexa dimmers with Fibaro 2 dimmers. Installed the first now and when Homey says it’s on it off and on when Homey says it’s off. Any solution to this?
Look at the Advanced parameters, for most devices the inputs can be inverted.
Otherwise, it probably can be done via RAW parameters.
I can’t find it in advanced parameters. RAW parameters is unknown to me. I am changing from Homeseer to Homey and my knowledge level is not to good in Homey yet.
Assuming there’s a momentary switch connected to the dimmer, isn’t it just a matter of the wrong pole of the switch being used or perhaps that the spring in the switch should be moved so the resting state of the switch changes?
It’s only controlled by Homey. No switch involved.
