[Feature Request] - "WHEN" "A Push notification was sent"
Hello!
I would like to use “A Push notification was sent” as a trigger for a flow. I have a Samsung with ONE UI 7 and after 49 notifications I don’t get any more notifications. If I could use this trigger I would be able to count notifications sent and send a critical alert when 40 notifications are sent and then reset notifications on the phone.
An example on what I would like to do in the attaced screenshot, but with another trigger.
Would also be nice if a specific user could be used as an “AND”-condition.
Workaround:
Call your flow in the screenshot ‘send notification to Tomas Johanson’
Replace send notification cards with
Start ‘flow’ with ‘text’ where the text is your message and flow is ‘send notification to Tomas Johanson’
Then you can use ‘this flow was started with tag’ as a trigger
Add after this trigger the send notification card where the message is the tag rhe flow started with.
Too many push or timeline notifications in a certain amount of time gets the service “rate limited” by Homey (not your phone). It just quits temporarily.
No one knows the exact conditions.
Solved by waiting 24h / Homey restart.
Consider adding the CallMeBot app’s Signal or Telegram services as second notification service and split the load.
Thanks for the suggestion! I have many “Confirm Notifications” so I decided to solve it by adding a timeline notification for every triggered notification/confirmation.
That doesn’t seem to be the case. If i dismiss my 49 notifications I will resume receiving notifications. Before UI 7 I stopped receiving notifications after 24. According to support (made a ticket) there is a limit in Android.
Thank you for your reply and apologies for te belated answer. I have asked the developers and they mention that this is unfortunately a limitation set by Android that we cannot get around. To be able to receive new notifications, you will need to swipe away the notifications that you have received.
So either they changed something between Android or One UI versions.
I will have a look at the suggested app! Thanks!
Thanks for elaborating!
