I use a Homey Pro with Matter-over-Thread devices and would like to request support for the Matter Binding cluster.
Use case: A Matter wall dimmer or remote should directly control Matter lights (on/off, level) without every command going through Homey Flows. Today this requires a Flow per device, adds hub latency and fails if Homey is busy or restarting.
Request:
- Let users create bindings from a Matter source device to one or more target devices or groups (UI in the device settings).
- Write the required Binding entries and Access Control List (ACL) entries on the target devices so the source is authorised to send commands.
- Support at least the On/Off and Level Control clusters, and keep bindings working when Homey is offline.
Why it matters: This is the Matter equivalent of Zigbee binding, which Zigbee2MQTT and ZHA already support. It gives lower latency, local resilience and less Flow clutter, and makes Matter-over-Thread a real replacement for Zigbee in this scenario.
Can you tell me whether this is on the roadmap, and which Matter version/features it depends on?
