I’m thinking about buying a Tesla Wall Connector but this doesn’t has an API to connect with Homey and doesn’t have power metering (AFAIK). I need to measure the total power on this charger so adding a DIN rail module on the fuse (32A) of the charger should do the trick. Would be great if I could see the values in Homey of course.
Or you can buy a (much cheaper) clamp and add it to your own hardware. Zappi for example sells a clamp for just under 20 euro: CT klem 5 meter - Myenergi BV (note: this requires tech knowledge; hardware and programming skills).
I have the Shelly 3EM the three phase version of the same equipment. One can see the power and cumulative energy in the insights. In Shelly android or ios app you can get more details based on hour, day, month and year
How can the Shelly 3EM be set up to see the energy going through the charger?
And can I use a Shelly 1 to turn the charger on/off through the pilot cable?
I really don’t recommend fiddling with the EV charger…
Doesn’t the charger have it’s own dedicated fuse/circuit breaker at the central mains fuse box (inside the house)?
Then the Shelly 3EM clamp solution is perfect imho, they’re not too expensive, and don’t interfere with the wires and connections.
Just put the three clamps around the three wires that run to the charger, a bit like this:
