I would like to use actual temperature measured by eurotronic zwave valves in a flow.
In homey, I can display the temperature but I have not found it as a variable I can use in a flow.
Thxs for help.
Thxs for help.
as with any temperature sensor, use the “logic” flow card(s) in the AND column which has “is higher/lower then” etc. as all values are available in tags
Thank you.
Paul
Thank you
Paul
