Error: Device: should be string
Since a few day, when i try to change something on a device, like change the Zone, i get this message:
device: should be string (#/properties/note/type)
Does anybody know this error and what to do?
regards Helle
Search the forum:
Bug. Keep your Homey app up-to-date.
I think this is due the latest update… just add a device note in the editing section at the bottom, where you can edit the device name
Hope there will be an update for that soon
Same here. Even when installed on an ipad, which has never seen homey before, i have the same problem. In the webapp I can change the zone.
Trick with putting something in the note-section works indeed. It even works when you remove this note later.
Hello @Em_Iks, it works, thanks a lot !
