Many thanks for creating the app! I used it to add EcoDim 10 Wave earlier, but given distance to Homey, I struggled, but that was not the only reason.
Adding the ZWave Dimmer indicates the user to double press the reset button to start the removal process. On the EcoDim 10 Zwave, manual, it states it needs a triple press instead, which blinks purple and then succeeds. Pressing the reset twice, actually tries to add the device while the config page is waiting for the removal sign, and does not receive it.
The DSK is also not printed nor via QR code legible. I found a DSK prefix in the manual and used this successfully. Not sure if you have a EcoDim 10 Zwave at your disposal, but happy to help you to details and screenshots if you need them to update the config!
I opened a topic on the Dutch forum, happy to translate if needed, but the above is the gist of it.
Dutch forum link
