Easee and dacia spring
Good morning.
I have an Easee charging station and a Dacia Spring. I would like to control them together. I created a flow, but there are still errors in it that I can’t spot. Has anyone created a flow to link these two devices?
I once received a flow from someone, but that was for an Amina.
thanks
Can you share your Flow? And what issues do you have with it?
Here is some information regarding the workflow:
Always charge the car battery up to 50%; do not charge it if the level is already above 50%. When there is abundant solar power, first charge the Luna battery (home battery) to 100%, then use the remaining power to charge the car. Ensure the P1 meter reading stays around 0W during this process; this means all surplus solar power is directed into the car. Include a manual toggle to switch between slow charging (8A) and fast charging (25A), as well as a manual control for “solar mode” (using surplus power). When the car is plugged in, first check whether the battery level is below or above 50%. When the cable is unplugged from the car, reset the manual control to “solar mode.” Also, if the system is manually set to slow or fast charging, ensure the other modes are deactivated.
Charging above 50% isn’t working.
The formula for calculating the solar surplus works—since I do get a value—but that value doesn’t seem to be reaching the right place via the cards to actually make it work.
How do I share a Flow? Thanks
I think this de flow to share.
“id”: “5b74f44c-f554-40a8-915d-1bb93e12f81f”,
“uri”: “homey:advancedflow:5b74f44c-f554-40a8-915d-1bb93e12f81f”,
“name”: “Laadpaal Dacia met equalizer 5 8 2026”,
“folder”: “b7a5fca5-6db1-4cb6-ade1-01ead15b00ce”,
“triggerable”: false,
“enabled”: true,
“broken”: false,
“cards”: {
“46258dcd-7b11-4c02-9b83-3c0cabd7df62”: {
“type”: “note”,
“value”: “Deel 1: Insteken = Meteen laden tot 50% ( winter/zomer)”,
“color”: “yellow”,
“x”: 0,
“y”: 0,
“width”: null,
“height”: null
“359a6e96-6f74-42cf-8e96-f5af57885f35”: {
“id”: “homey:manager:logic:lt”,
“droptoken”: “homey:device:8f3a2976-43f3-403d-a0d5-edf2100dab18|measure_battery”,
“args”: {
“comparator”: “[[homey:manager:logic|4c6bd33d-8cc0-401f-8d8f-c113594487fb]]”
“type”: “condition”,
“x”: 820,
“y”: 200,
“outputTrue”: [
“47a009e2-775e-448f-9a4a-8092d53843a0”
“5fbbdf64-b242-4c79-8752-b53e070ab22d”: {
“type”: “note”,
“value”: “Deel 2: De rekenmachine (voorrang op de thuisbatterij)”,
“color”: “yellow”,
“x”: 0,
“y”: 880,
“width”: null,
“height”: null
“8feb1163-7001-4315-a2e4-c265bbe11789”: {
“id”: “homey:manager:cron:every_nth”,
“args”: {
“n”: 5,
“type”: “minute”
“type”: “trigger”,
“x”: 0,
“y”: 1020,
“outputSuccess”: [
“477341f3-710e-4a75-9c6b-22d0c59e2a1b”
“014c79c0-5512-42d4-8ce4-772f10566369”: {
“type”: “note”,
“value”: “Deel 3: Lijn A: \nDe Easee Laadpaal aansturen en Wolken Timer; zon aanwezig”,
“color”: “yellow”,
“x”: 0,
“y”: 1180,
“width”: null,
“height”: null
“7d31dd3e-8f76-40c0-9179-ab37b6f1e1fa”: {
“id”: “homey:manager:logic:gt”,
“droptoken”: “homey:manager:logic|ac9ef552-eb98-4505-babf-f9984c77ca08”,
“args”: {
“comparator”: 5
“x”: 720,
“y”: 1500,
“outputTrue”: [
“b929abbc-acc5-49da-8db6-c54be5c03c51”
“f89e3a50-d881-4e1f-9a85-a83688e97f65”: {
“args”: {
“comparator”: 6
“x”: 380,
“y”: 1860,
“outputTrue”: [
“2ed87802-e9a7-499d-b9e2-b621ea8e2625”
“d40318d2-410f-46cb-8f18-f7e4ba647871”: {
“id”: “homey:app:nl.bevlogenheid.countdown:timer_running”,
“args”: {
“variable”: {
“name”: “wolken_Timer_Easee”,
“type”: “number”,
“description”: “Just added”
“x”: 1700,
“y”: 2160,
“outputTrue”: [
“740bf3c2-58a2-4bf6-bca1-489e5aa8fe89”
“740bf3c2-58a2-4bf6-bca1-489e5aa8fe89”: {
“id”: “homey:app:nl.bevlogenheid.countdown:set_countdown_timer_with_unit”,
“args”: {
“variable”: {
“type”: “number”,
“value”: “30”,
“unit”: “minutes”
“type”: “action”,
“x”: 2100,
“y”: 2160
“02740258-5f90-4d3d-ac38-e993847ac459”: {
“id”: “homey:app:nl.bevlogenheid.countdown:countdown_to_zero”,
“args”: {
“variable”: {
“type”: “number”,
“type”: “trigger”,
“x”: 0,
“y”: 2960,
“outputSuccess”: [
“93478f65-8b1e-4e38-999b-b8a97b7c9455”
“986c3258-a1fc-4e55-9a92-606b2488062d”: {
“id”: “homey:manager:logic:variable_set_number_math”,
“args”: {
“variable”: {
“id”: “ac9ef552-eb98-4505-babf-f9984c77ca08”,
“name”: “MAX_Doel_Laadstroom_Auto”
“value”: “{{min(25,max(0,floor((([[homey:device:e4e85c05-e665-42f6-9358-619f2bcbca42|measure_power]]*-1)+[[homey:device:496dc23a-e5b7-4baa-a126-8badc079f1a2|measure_power]]+min(0,[[homey:device:ef5acf60-cde6-4ab6-b181-b50638058e4e|measure_power]]))/230)))}}”
“type”: “action”,
“x”: 1000,
“y”: 1020,
“outputSuccess”: [
“3a7ab374-f0ca-4e51-b565-605b33598c86”
“12e8ff6b-1457-4076-89f4-ae16c50cdf84”: {
“id”: “homey:manager:logic:equal_boolean”,
“droptoken”: “homey:manager:logic|f39e24df-92b9-41d9-9270-39651822c0ef”,
“x”: 420,
“y”: 220,
“inverted”: true,
“outputTrue”: [
“d05ccd19-af0b-42ce-a6de-953d2d29c9d5”: {
“id”: “homey:manager:logic:equal”,
“args”: {
“x”: 800,
“y”: 480,
“outputTrue”: [
“fc6b38e3-3cff-474d-9e7e-fb39fba15d27”
“fbf29f28-f1d1-44e0-b01b-61ea9943965d”: {
“x”: 400,
“y”: 580,
“inverted”: true,
“outputTrue”: [
“d05ccd19-af0b-42ce-a6de-953d2d29c9d5”,
“773f161e-dc4f-4084-88d3-943955ffe617”
“477341f3-710e-4a75-9c6b-22d0c59e2a1b”: {
“x”: 420,
“y”: 1020,
“inverted”: true,
“outputTrue”: [
“eb234722-5830-4a5f-92eb-d5512a7d43a0”: {
“x”: 720,
“y”: 1400,
“inverted”: true,
“outputTrue”: [
“b929abbc-acc5-49da-8db6-c54be5c03c51”: {
“type”: “all”,
“x”: 1180,
“y”: 1420,
“input”: [
“eb234722-5830-4a5f-92eb-d5512a7d43a0::outputTrue”,
“7d31dd3e-8f76-40c0-9179-ab37b6f1e1fa::outputTrue”,
“0976ceef-cbe9-432f-b820-bc908d64bc7b::outputTrue”
“outputSuccess”: [
“efdaa59b-3e3e-48a2-98a7-75998130f03e”
“6db4630e-bed7-492a-82c2-146bc27fdac5”: {
“type”: “note”,
“value”: “Deel 3: Lijn B:\nDe Easee Laadpaal aansturen met wolk / Te weinig zon ( timer starten”,
“color”: “yellow”,
“x”: 340,
“y”: 1720,
“width”: null,
“height”: null
“058dc718-f22d-49cb-b51e-104962adfa30”: {
“x”: 380,
“y”: 1960,
“inverted”: true,
“outputTrue”: [
“2ed87802-e9a7-499d-b9e2-b621ea8e2625”: {
“type”: “all”,
“x”: 940,
“y”: 2000,
“input”: [
“f89e3a50-d881-4e1f-9a85-a83688e97f65::outputTrue”,
“058dc718-f22d-49cb-b51e-104962adfa30::outputTrue”,
“d8fd94f2-16e1-4817-ab32-015bfcc01783::outputTrue”
“outputSuccess”: [
“9db046fb-597b-4121-87f6-4c6f2b0b6781”
“d91ac8e1-32ba-4a65-8a3c-8bec232f5684”: {
“type”: “note”,
“value”: “Deel 3: Lijn C:\nTimer Loopt af.”,
“color”: “yellow”,
“x”: 0,
“y”: 2820,
“width”: null,
“height”: null
“93478f65-8b1e-4e38-999b-b8a97b7c9455”: {
“x”: 440,
“y”: 2960,
“inverted”: true,
“outputTrue”: [
“245a0c8b-eb53-4022-a61f-5a77ac36f0be”,
“b080d613-f763-4d3e-82b2-c5fa1b2bc5bf”
“8c325824-dd1d-4c17-b9ff-801713ef0055”: {
“type”: “note”,
“value”: “Deel 4: Actie1:\nHandmatig Fast”,
“color”: “yellow”,
“x”: 0,
“y”: 3500,
“width”: null,
“height”: null
“eb7591b8-5352-4c83-9c45-f185841fd831”: {
“id”: “homey:device:eca88f0d-6871-4175-95b9-f01c974be82e:onoff_true”,
“type”: “trigger”,
“x”: 0,
“y”: 3620,
“outputSuccess”: [
“0786b031-145b-43d1-bf95-7af360ed3c9e”
“0786b031-145b-43d1-bf95-7af360ed3c9e”: {
“id”: “homey:manager:logic:variable_set_boolean”,
“args”: {
“variable”: {
“id”: “f39e24df-92b9-41d9-9270-39651822c0ef”,
“name”: “LP_Handmatig_Modus”
“value”: true
“type”: “action”,
“x”: 380,
“y”: 3620,
“outputSuccess”: [
“863a1a03-96fa-4cc4-acda-9d04b57bafac”
“144e26c3-87d2-4004-a82c-50fda4a6d4f2”: {
“id”: “homey:device:cdf56dc3-996d-4ea6-894a-5ca326c29701:onoff_true”,
“type”: “trigger”,
“x”: 0,
“y”: 4280,
“outputSuccess”: [
“8656e228-f1e4-45bd-874b-8ae56863f4e2”
“8656e228-f1e4-45bd-874b-8ae56863f4e2”: {
“args”: {
“variable”: {
“value”: true
“type”: “action”,
“x”: 380,
“y”: 4280,
“outputSuccess”: [
“ebfaa318-bd4a-4543-b2ad-7879e117c2c4”
“5f9266ab-dbd4-4239-9a38-2df7ba378733”: {
“type”: “note”,
“value”: “Deel 4: Actie 2: \nHandmatig Traag”,
“color”: “yellow”,
“x”: 0,
“y”: 4120,
“width”: null,
“height”: null
“51eb365e-ebb9-46d2-92c6-0ad45c848bfd”: {
“type”: “note”,
“value”: “Deel 4: Actie 3:\nReset naar Auto / Zon”,
“color”: “yellow”,
“x”: 0,
“y”: 4700,
“width”: null,
“height”: null
“6f392954-6b3c-4c42-af2c-95d8cec2efd6”: {
“id”: “homey:device:80a93ba8-23e8-40da-86ce-00f06f9b9a27:onoff_true”,
“type”: “trigger”,
“x”: 0,
“y”: 4820,
“outputSuccess”: [
“b571cda5-f8c3-4869-8243-376794738c7e”
“b571cda5-f8c3-4869-8243-376794738c7e”: {
“args”: {
“variable”: {
“value”: false
“type”: “action”,
“x”: 400,
“y”: 4820,
“outputSuccess”: [
“4629721f-6b46-4fed-83ef-3b7d6fa0bbd6”
“9aa22940-25f3-4130-b61a-2d9b71c2bc1c”: {
“type”: “note”,
“value”: “dit verder bekijken”,
“color”: “yellow”,
“x”: 1360,
“y”: 940,
“width”: null,
“height”: null
“5ba548c0-e6b2-4bb5-aa26-937b055d7d26”: {
“id”: “homey:device:496dc23a-e5b7-4baa-a126-8badc079f1a2:evcharger_charging_start”,
“type”: “action”,
“x”: 1680,
“y”: 320,
“outputSuccess”:
“773f161e-dc4f-4084-88d3-943955ffe617”: {
“args”: {
“x”: 780,
“y”: 620,
“outputTrue”: [
“fc6b38e3-3cff-474d-9e7e-fb39fba15d27”: {
“type”: “any”,
“x”: 1180,
“y”: 580,
“outputSuccess”: [
“1e50206c-3b06-49e6-9e78-c8b9df3dee9f”
“47a009e2-775e-448f-9a4a-8092d53843a0”: {
“id”: “homey:device:496dc23a-e5b7-4baa-a126-8badc079f1a2:setDynamicChargerCurrent”,
“args”: {
“current”: 8
“type”: “action”,
“x”: 1440,
“y”: 180,
“outputSuccess”: [
“a7ceb1b7-206e-46be-a2f6-afa67d029d1e”
“e5791fa3-2598-4490-9804-568a0eafdb07”: {
“args”: {
“current”: “[[homey:manager:logic|ac9ef552-eb98-4505-babf-f9984c77ca08]]”
“type”: “action”,
“x”: 1520,
“y”: 1300,
“outputSuccess”: [
“ec221759-a117-404f-af3e-d441aab4c7b5”
“55c492c8-5b47-4789-a907-7d5f9a1ea36d”: {
“type”: “note”,
“value”: “Deel 4: Actie 4 automatische reset bij ontkoppelen auto naar de zon opladen”,
“color”: “yellow”,
“x”: 0,
“y”: 5040,
“width”: null,
“height”: null
“7389eb09-45c3-40cc-9ba0-5d39195a9559”: {
“id”: “homey:device:496dc23a-e5b7-4baa-a126-8badc079f1a2:evcharger_charging_state_changed”,
“type”: “trigger”,
“x”: 0,
“y”: 5160,
“outputSuccess”: [
“d8c14796-0941-49a9-bbd0-e34d7908d150”
“args”: {
“state”: “plugged_out”
“d8c14796-0941-49a9-bbd0-e34d7908d150”: {
“x”: 480,
“y”: 5160,
“inverted”: false,
“outputTrue”: [
“1bfb56fc-ba24-4cd0-bcd1-8c00955eab64”
“2b0c3f1d-3a1f-49ad-b143-8cabfe54c3e4”: {
“args”: {
“variable”: {
“value”: false
“type”: “action”,
“x”: 1320,
“y”: 5260,
“outputSuccess”: [
“a41b8728-32c6-4bab-90fe-319c1adf81f9”
“a41b8728-32c6-4bab-90fe-319c1adf81f9”: {
“id”: “homey:app:nl.bevlogenheid.countdown:stop_countdown_timer”,
“args”: {
“variable”: {
“type”: “number”,
“type”: “action”,
“x”: 1640,
“y”: 5100,
“outputSuccess”: [
“f5788500-08bd-4777-ba6a-d96ce0d292d6”
“f5788500-08bd-4777-ba6a-d96ce0d292d6”: {
“type”: “action”,
“x”: 2100,
“y”: 5100,
“outputSuccess”: ,
“args”: {
“current”: 8
“3a7ab374-f0ca-4e51-b565-605b33598c86”: {
“id”: “homey:manager:notifications:create_notification”,
“args”: {
“text”: “de berekende laadstroom is nu: [[homey:manager:logic|ac9ef552-eb98-4505-babf-f9984c77ca08]]”
“type”: “action”,
“x”: 1540,
“y”: 1040,
“outputSuccess”: [
“b843218d-5ce3-4e0b-9571-987a8db605cc”
“f3d435e2-cecc-44cf-9b82-c849ed24da8e”: {
“args”: {
“current”: 8
“type”: “action”,
“x”: 1320,
“y”: 2180,
“outputSuccess”: [
“d8fd94f2-16e1-4817-ab32-015bfcc01783”: {
“id”: “homey:device:496dc23a-e5b7-4baa-a126-8badc079f1a2:evcharger_charging”,
“x”: 380,
“y”: 2060,
“outputTrue”: [
“863a1a03-96fa-4cc4-acda-9d04b57bafac”: {
“id”: “homey:device:cdf56dc3-996d-4ea6-894a-5ca326c29701:off”,
“type”: “action”,
“x”: 620,
“y”: 3500,
“outputSuccess”: [
“6af6db2b-5335-486a-ab61-3b6725ecc592”
“6af6db2b-5335-486a-ab61-3b6725ecc592”: {
“id”: “homey:device:80a93ba8-23e8-40da-86ce-00f06f9b9a27:off”,
“type”: “action”,
“x”: 800,
“y”: 3740,
“outputSuccess”: [
“8620b64a-84c7-4b84-88e5-3179e2c7bad4”
“c86cf40a-1aa7-4c3f-b0da-d30426606dd7”: {
“type”: “action”,
“x”: 760,
“y”: 4400,
“outputSuccess”: [
“6e1bdd2b-446c-4cca-a3a2-01149bb9cf20”
“ebfaa318-bd4a-4543-b2ad-7879e117c2c4”: {
“id”: “homey:device:eca88f0d-6871-4175-95b9-f01c974be82e:off”,
“type”: “action”,
“x”: 580,
“y”: 4180,
“outputSuccess”: [
“4629721f-6b46-4fed-83ef-3b7d6fa0bbd6”: {
“type”: “action”,
“x”: 840,
“y”: 4820,
“outputSuccess”: [
“e9549417-6fca-4dae-89e2-0e6f99ed94a3”
“e9549417-6fca-4dae-89e2-0e6f99ed94a3”: {
“type”: “action”,
“x”: 1280,
“y”: 4820
“04ba727c-bb71-47bc-9bd7-89379dabd680”: {
“type”: “any”,
“x”: 420,
“y”: 1520,
“outputSuccess”: [
“eb234722-5830-4a5f-92eb-d5512a7d43a0”,
“7d31dd3e-8f76-40c0-9179-ab37b6f1e1fa”,
“0976ceef-cbe9-432f-b820-bc908d64bc7b”
“e70e8f09-1eb5-45e7-a8f9-5f24b9d2f512”: {
“type”: “any”,
“x”: 160,
“y”: 2060,
“outputSuccess”: [
“f89e3a50-d881-4e1f-9a85-a83688e97f65”,
“058dc718-f22d-49cb-b51e-104962adfa30”,
“5bd967c9-dfea-40b8-bdf6-7c04a57e13fc”: {
“args”: {
“type”: “action”,
“x”: 1660,
“y”: 680,
“outputSuccess”: [
“bcb556a7-9576-4bc1-8861-3565ebb529ac”
“734c0c7d-ff81-4e19-a085-d6d4b5ea73c0”: {
“id”: “homey:device:496dc23a-e5b7-4baa-a126-8badc079f1a2:charger_status_changedv2”,
“args”: {
“status”: {
“id”: “6”,
“name”: “Car connected”
“type”: “trigger”,
“x”: 0,
“y”: 220,
“outputSuccess”: [
“206819e9-2901-4ae5-979c-a9f37614aad2”: {
“args”: {
“status”: {
“id”: “6”,
“type”: “trigger”,
“x”: 0,
“y”: 580,
“outputSuccess”: [
“b843218d-5ce3-4e0b-9571-987a8db605cc”: {
“type”: “any”,
“x”: 120,
“y”: 1580,
“outputSuccess”: [
“04ba727c-bb71-47bc-9bd7-89379dabd680”,
“ce3aaa53-0209-426d-95cb-e9c46dea4e08”: {
“type”: “action”,
“x”: 2300,
“y”: 1500
“e429c27d-785d-4a15-ada3-26e77dc306c1”: {
“type”: “action”,
“x”: 1580,
“y”: 4200,
“outputSuccess”: [
“1067f60d-1119-4c97-98ba-788976d3163e”
“args”: {
“current”: 8
“1067f60d-1119-4c97-98ba-788976d3163e”: {
“type”: “delay”,
“args”: {
“delay”: {
“number”: “5”,
“multiplier”: 1
“x”: 1960,
“y”: 4380,
“outputSuccess”: [
“477960d6-5d0f-443e-b257-3045f580e088”
“cf97164f-f702-4a49-9451-5fd9892ccebc”: {
“type”: “delay”,
“args”: {
“delay”: {
“number”: “10”,
“multiplier”: 1
“x”: 1960,
“y”: 3740,
“outputSuccess”: [
“8008bd65-f0aa-41ba-9150-2fefe91b56ec”
“8008bd65-f0aa-41ba-9150-2fefe91b56ec”: {
“type”: “action”,
“x”: 2120,
“y”: 3620
“477960d6-5d0f-443e-b257-3045f580e088”: {
“type”: “action”,
“x”: 2180,
“y”: 4160
“988f6045-bde9-4b59-a972-48ed4a485640”: {
“type”: “action”,
“x”: 1520,
“y”: 3620,
“outputSuccess”: [
“args”: {
“current”: 25
“a7ceb1b7-206e-46be-a2f6-afa67d029d1e”: {
“type”: “delay”,
“args”: {
“delay”: {
“number”: “10”,
“multiplier”: 1
“x”: 1840,
“y”: 200,
“outputSuccess”: [
“1bfb56fc-ba24-4cd0-bcd1-8c00955eab64”: {
“type”: “action”,
“x”: 860,
“y”: 5160,
“outputSuccess”: [
“7abb16b5-0f09-4883-90fb-c35b3f307013”
“7abb16b5-0f09-4883-90fb-c35b3f307013”: {
“type”: “action”,
“x”: 1040,
“y”: 5040,
“outputSuccess”: [
“efdaa59b-3e3e-48a2-98a7-75998130f03e”: {
“type”: “delay”,
“args”: {
“delay”: {
“number”: “5”,
“multiplier”: 1
“x”: 1460,
“y”: 1600,
“outputSuccess”: [
“8620b64a-84c7-4b84-88e5-3179e2c7bad4”: {
“type”: “delay”,
“args”: {
“delay”: {
“number”: “5”,
“multiplier”: 1
“x”: 1340,
“y”: 3620,
“outputSuccess”: [
“6e1bdd2b-446c-4cca-a3a2-01149bb9cf20”: {
“id”: “homey:device:496dc23a-e5b7-4baa-a126-8badc079f1a2:chargerState”,
“type”: “action”,
“x”: 1160,
“y”: 4400,
“outputSuccess”: [
“77b57e71-8798-4db2-9197-6c3fd2126e20”
“args”: {
“chargerState”: “true”
“77b57e71-8798-4db2-9197-6c3fd2126e20”: {
“type”: “delay”,
“args”: {
“delay”: {
“number”: “5”,
“multiplier”: 1
“x”: 1460,
“y”: 4300,
“outputSuccess”: [
“f6122103-a26e-41fe-a575-53a90f6cc44b”: {
“type”: “action”,
“x”: 2320,
“y”: 720,
“outputSuccess”:
“6bf625c7-c9a2-4c72-84a7-c670195775c3”: {
“x”: 1900,
“y”: 1520,
“inverted”: true,
“outputTrue”: [
“205ba233-6cc9-4861-b7d2-782da8545507”: {
“args”: {
“comparator”: 5
“x”: 1780,
“y”: 500,
“outputTrue”: [
“ec221759-a117-404f-af3e-d441aab4c7b5”: {
“type”: “delay”,
“args”: {
“delay”: {
“number”: “10”,
“multiplier”: 1
“x”: 1920,
“y”: 1340,
“outputSuccess”: [
“6bf625c7-c9a2-4c72-84a7-c670195775c3”,
“af6d84ee-70df-4a08-8927-27e2a75b089c”
“af6d84ee-70df-4a08-8927-27e2a75b089c”: {
“args”: {
“variable”: {
“type”: “number”,
“type”: “action”,
“x”: 2140,
“y”: 1260
“bcb556a7-9576-4bc1-8861-3565ebb529ac”: {
“type”: “delay”,
“args”: {
“delay”: {
“number”: “10”,
“multiplier”: 1
“x”: 2120,
“y”: 720,
“outputSuccess”: [
“1e50206c-3b06-49e6-9e78-c8b9df3dee9f”: {
“id”: “homey:device:496dc23a-e5b7-4baa-a126-8badc079f1a2:pauseCharging”,
“args”: {},
“type”: “action”,
“x”: 1360,
“y”: 540,
“outputSuccess”: [
“0976ceef-cbe9-432f-b820-bc908d64bc7b”: {
“args”: {
“x”: 720,
“y”: 1600,
“outputTrue”: [
“9db046fb-597b-4121-87f6-4c6f2b0b6781”: {
“args”: {
“x”: 900,
“y”: 2200,
“outputTrue”: [
“245a0c8b-eb53-4022-a61f-5a77ac36f0be”: {
“type”: “action”,
“x”: 840,
“y”: 2960,
“outputSuccess”: [
“cac7d9e4-a8d3-451b-a998-e249ee5b6410”
“b080d613-f763-4d3e-82b2-c5fa1b2bc5bf”: {
“id”: “homey:device:80a93ba8-23e8-40da-86ce-00f06f9b9a27:on”,
“type”: “action”,
“x”: 840,
“y”: 3060,
“outputSuccess”: [
“39c40b88-792b-4b64-8e1c-41069cacd045”: {
“id”: “homey:device:cdf56dc3-996d-4ea6-894a-5ca326c29701:onoff_false”,
“type”: “trigger”,
“x”: 0,
“y”: 4520,
“outputSuccess”: [
“b7302012-b632-40ec-a1d9-f4bc046b7adc”
“b7302012-b632-40ec-a1d9-f4bc046b7adc”: {
“args”: {
“variable”: {
“value”: false
“type”: “action”,
“x”: 420,
“y”: 4520,
“outputSuccess”: [
“af8b3b41-c6fd-4ba6-884a-c14e72c0802f”
“af8b3b41-c6fd-4ba6-884a-c14e72c0802f”: {
“type”: “action”,
“x”: 860,
“y”: 4520,
“outputSuccess”:
“c191a046-7cff-4381-99e0-ff8a768841cf”: {
“id”: “homey:device:eca88f0d-6871-4175-95b9-f01c974be82e:onoff_false”,
“type”: “trigger”,
“x”: 0,
“y”: 3900,
“outputSuccess”: [
“04a17e03-a16e-4160-975e-a98544cd0b58”
“04a17e03-a16e-4160-975e-a98544cd0b58”: {
“args”: {
“variable”: {
“value”: false
“type”: “action”,
“x”: 420,
“y”: 3900,
“outputSuccess”: [
“489ef61d-4926-41a6-9c37-e87873070472”
“489ef61d-4926-41a6-9c37-e87873070472”: {
“type”: “action”,
“x”: 860,
“y”: 3900,
“outputSuccess”:
“3b4a4d14-2807-4ab0-96e1-fa1311e6978f”: {
“args”: {},
“type”: “action”,
“x”: 1640,
“y”: 2960,
“outputSuccess”:
“cac7d9e4-a8d3-451b-a998-e249ee5b6410”: {
“type”: “all”,
“x”: 1320,
“y”: 2960,
“input”: [
“245a0c8b-eb53-4022-a61f-5a77ac36f0be::outputSuccess”,
“b080d613-f763-4d3e-82b2-c5fa1b2bc5bf::outputSuccess”
“outputSuccess”: [
Please consider using the following options when posting logs, code, etc., to increase readability of your post:
  • Preformatted text option to keep the output in the original format and presented in a scrollable window. This reduces the length of your post.
  • Hide details option, to collapse/hide the entire interview output. Clicking the collapsed item will show the interview output again.
You can read how to share flows here
