Does anyone have any advanced flow for earth hour - so lights that already is off will be off when the earth our is over, and the lights that have been turned off will turn to on again.
Thanks
Thanks
Zone memory app can do that.
I use the IcalCalendar App for such purposes, e.g. Earth Hour or while Advent.
The outdoor lights will be switched between 15:00 - 21:55 o’clock on depending of the outdoor brightness, but only if currently is not the Earth Hour:
If the lights are already switched on earlier and the Earth Hour begins, then the lights will be switched off:
If Earth Hour ends, the lights are switched on again:
With the IcaCalender App I control many more things individually. For example, if we have vacations, weekend or if it’s a public holiday the shutters will be opened later than on “normal” days.
Thanks for the suggestions, very helpful. ![]()
