[DoS attack: Smurf] attack packets in last 20 sec from ip
192.168.23.8 is my Homey. It doesn’t resolve anything:
$ nslookup homey.app 192.168.23.8
;; connection timed out; no servers could be reached
Regarding your followup post: how do you know the traffic is coming from Homey when the packets arrive on your external interface? Do you have a Netgear router? If so, read this post about those generating a lot of false positives when it comes to DoS attack alerts.
I’m blocking the homey ip, and the traffic disappear
How do you know it’s not regular normal traffic? The DNS amplification issue that you mention is not relevant because your Homey is located in an internal network and no outside attackers can abuse it (unless you have a very badly configured network).
Tried NSlookup while using Wireshark also but I didn’t receive any response… on UDP.
On TCP however, Homey did respond.
However I’m not an expert on Wireshark so I can’t tell if the responses are ‘wrong’
There’s something running on TCP port 53, but at least with firmware v4.2, it just closes the connection immediately:
$ dig +tcp @192.168.23.8 homey.app
;; communications error to 192.168.23.8#53: end of file
Hey I had similair symptoms myself recently. Out of the blue I had wierd lan issues each time I stream out data(share screen etc) I loose connectivity. I see same error you guys did in netgear logs. I tried turn of netgear app in Homey but with no succces. I turn of homey and problems gone, however my entire house stop working because everything connected to the homey.
You suspect it has something to do with homey passive device scan. Can you turn it off or make The neetgear chill of?
Am using The 5.0 beta though
Hi, what is the status of these ‘Smurf attacks’ originating from Homey? I have the same thing: warning about possible Smurf attacks from my Homey address at a fixed interval of 15 minutes, from my router:
Mar 17 18:00:41 Firewall attack: Smurf attack ->IN=br0 OUT= MAC= xxx SRC=192.168.178.xx
Mar 17 18:15:37 Firewall attack: Smurf attack ->IN=br0 OUT= MAC= xxx SRC=192.168.178.xx
https://images.app.goo.gl/JPpQpXd3SuiUKaB47
Athom doesn’t care: MAC discovery relies on broadcast pings that not all devices respond to · Issue #148 · athombv/homey-apps-sdk-issues · GitHub
Ok, thanks for the link @robertklep , guess we can ignore this then.
Yes, just like Athom does :wink:
I have also notis this and I could ignore it but the problem is that the router lose connection to all devices during the DoS and that is a hard to ignore problem. I have tried to disable Port Scan and DoS Protection on my netgear router but that does not help.
So how do I solve it?
If you can’t disable it in your router, you can’t solve it. You can try submitting a support request but I don’t have high hopes that Athom will do anything about it.
Using an old thread, but I think it’s the same issue.
Since an hour ago I get these messages from my firewall:
DOS][Block][smurf][homey-ip->192.168.11.255][ICMP][HLen=20, TLen=84, Type=8, Code=0]
They keep coming back (still going on) every 2 or 3 minutes.
I have never seen these before and I don’t believe Homey was updated in the last hours (12.2.1).
Is there a way to stop this? I already rebooted Homey
There’s no way to stop this, this is “normal”.
Oké, but why did it start today after running for years.
i whitelisted my Homey in my firewall so it stops sending warning emails, but wondering if it is a security issue.
It could be indirectly caused by an app you installed, the culprit is Athom’s implementation of “MAC discovery”.
It’s not a security issue, just an annoyance. I mentioned this behaviour to Athom more than 4 years ago already.
Oke, thanks.
I didn’t change anything in my setup in the last weeks, so no Idea what could have triggered this.
My knowledge of networking is not that great, I think I remembered the .255 address is for broadcasting?
But good to know it’s not a security issue.
Thanks
Correct, Homey does a ping to the local broadcast address to find devices (with the assumption that all devices respond to that, which they don’t).
