DIY Voice controlled Tasmota IR transmitter
Hi Homey friends,
I like to share my IR project what I started to control my ceiling fan in the bedroom with google mini. It’s a ceiling fan controlled by an IR remote with 3 different speed settings. I hope it will inspire some people with their projects.
It took me some time to understand how to get it working, but the information on this forum and some other places got me in the right direction. Tried to explained all the collected information for this project in this post.
The 5 voice command I can use are:
  • Oke google, Fan on
  • Oke google, Fan off
  • Oke google, Fan speed 1 on
  • Oke google, Fan speed 2 on
  • Oke google, Fan speed 3 on
1. First I had to make an Arduino flashed with Tasmota IR-Firmware and an electrical circuit for the IR transmitter.
I used an ESP8266, IR receiver on jack, 5V adapter, a case and some electrical parts. The IR transmitter led was taken from an old remote.
I used this electrical circuit described on the Tasmota site https://tasmota.github.io/docs/IR-Remote/
2. Setup Tasmota data pins for IR TX and RX and the MQTT settings to talk with Homey.
I used pin D1 for IR RX and pin D5 for IR TX. D4 is the internal led on the ESP8266 to check if the device has power.
In MQTT settings you need to put the IP adres of the broker, I installed a broker on my synology NAS, so the IP adres is from my NAS. Username and password you have setup in the broker and a MQTT topic of your choice.
Full Topic needs to be left on default setting.
To know what IR command I need to send from homey I went to the console in the Tasmota web interface and push a button on the IR remote. When I tested it with my TV remote you see in the response something like this:
{“Protocol”:“SAMSUNG”,“Bits”:32,“Data”: 0xE0E040BF}
To test if it works you can type irsend before it in the console line:
irsend {“Protocol”:“SAMSUNG”,“Bits”:32,“Data”: 0xE0E040BF}
Unfortunately all the buttons on my fan remote gave the same code, so I needed to switch to RAW IR commands by typing “SetOption58 1” in console line. If you press a button on the remote you see something like this:
+1285-395A-400+445-1235DeDeD-1240DeDeDeDeDe+450-7960AbAbDeDeDeAbAb+1290bAbAbAbA-7120AbAbDeDeDeDeDfAbDeDeDeD-7970+1280bAbDeDeDeDeDeIbDeDeDeD-7965AbAbDeDfDeDfDeAbDeDeDf+440mAbAbDeDfDeDeDeAbDeDeDeDmAbIbDeDeDeDfDeAbDfDfDfDmAbAbDeDeDeDeDfA-390DeDfNeDmAbAbDeGeDfDeDfLbDeDeDeDmAbAbDfDeDfDeDfAbDeDeDeD
You need to put “0,” before the code to set the frequency to 38kHz what is the frequency used for Infrared codes.
irsend 0,+1285-395A-400+445-1235DeDeD-1240DeDeDeDeDe+450-7960AbAbDeDeDeAbAb+1290bAbAbAbA-7120AbAbDeDeDeDeDfAbDeDeDeD-7970+1280bAbDeDeDeDeDeIbDeDeDeD-7965AbAbDeDfDeDfDeAbDeDeDf+440mAbAbDeDfDeDeDeAbDeDeDeDmAbIbDeDeDeDfDeAbDfDfDfDmAbAbDeDeDeDeDfA-390DeDfNeDmAbAbDeGeDfDeDfLbDeDeDeDmAbAbDfDeDfDeDfAbDeDeDeD
3. Setup Virtual Switches and an advanced flow in Homey.
I created 4 Virtual switches with the app Virtual Devices that has the option to set a switch mode without trigger. To set the right one on and off I made a nice spiderweb :stuck_out_tongue:
When google sets the chosen switch on it sends the corresponding RAW IR command to the MQTT Topic “ir” and updates the fan speed logic to the chosen speed number. Because of the logic the fan wil be going to the last speed value that was used the last time when you say “Oke google, Fan on”
The divergence between the Tasmota console and sending commands thru MQTT Client App is that you need to put “cmnd/TOPIC/COMMAND” in the topic section and the message in the send section. In my case: cmnd/ir/irsend
@Robinjo I am trying to do same and it working fine based on your above guide. Additionally, if i wanted to create a reverse with way and update the status to a virtual button. Example physically remote pressed, tasmota-ir detect the signal and update the homey virtual button.
Do anyone know how to setup?
@Shiki you can filter the incoming MQTT data like this. The only thing I noticed. That the RawData is every time divergent at the moment. It was not when I set it up in the summer of 2022. I’m still on tasmota firmware 12.1.1.1 Maybe this is fixed in the other firmwares, or the remote is being added in de IR firmware nowadays so you don’t need the RawData.
@Robinjo Appreciate your reply, based on your advanced flow I managed to receive messages. I created a simple test on advanced flow and it works!
I am running on current tasmota firmware 12.5.0, there are many devices unknown too but, it comes with hash code which is unique to being recognised.
Example below:
IrReceived":{“Protocol”:“UNKNOWN”,“Bits”:132,“Hash”:“0xF97F76B9”,“Repeat”:0,“RawData”:“+3500-1740+450-1290C-420CeCeCdCeCeCeCeCdCeCdCdCeCdCdCdCdCdCeCdCeC-425+445dCeCe_TRUNCATED”,“RawDataInfo”:[263,263,0]}}
Thats good to know @Shiki Thanks for that
