I had a problem with my home battery discharging due to the Nymo charging. The standard flow (power has changed → Set excess power to #power) interprets feed-in as excess solar energy. I solved this as follows by adding flows:
- Battery charge status has changed Discharge (Indevolt) → Turn off (Solyx)
- Battery charge status has changed Inactive (Indevolt) → Turn on (Solyx) - Delay 3 sec. → Set excess power to #power (inverted Yes )
- Battery charge status has changed Charge (Indevolt) → Turn on (Solyx) - Delay 3 sec. → Set excess power to #power (inverted Ye s)
I also left the standard flow in place. This seems to work. I am just wondering if the Nymo is switching too much now.Does anyone possibly know a better solution?
