Devolo Rauchmelder, Wassersensor und Alarmsirene
Ich habe bereits 5 Anfragen zur Weiterentwicklung der Devolo App eingereicht. Sie wurden immer ignoriert.
Hier nun nochmal meine 6te Anfrage, die ich zeitgleich im Forum poste um mehr Aufmerksamkeit zu erhalten!
Devolo
Smoke Detector,
Water Leak Sensor,
Alarm Siren
I said it five times before, but my request was always ignored…
Now it is finally happening: Devolo turns off its Servers at 31.12.2025. So why does Homey pro still not support the smoke detectors, the water leak sensors and the sirens?
See here: https://www.housecontrollers.de/smart-home/abschal… (official announcement 21/08/2025 at https://www.devolo.de/ueber-devolo/presse/devolo-kuendigt-abschaltung-der-home-control-server-an-smart-home-bausteine-sind-weiterhin-nutzbar?utm_source=chatgpt.com **)**
As I said often before: It is a WIN-WIN-Situation for users and Homey. There is a company called ROCKETHOME that fishes off Devolo Users by selling a moving service to integrate ALL Devolo devices to their gatewway (399 EUR Gateway single price or 129 EUR subscription for 1 year).
So Homey…really…“dont be stupid”… integrate the last missing devices finally!
Why not picking off the desperate Devolo Commmunity by yourself?
If possible I will support you doing this. If you need any information about the missing devices I can give them to you.
Thanks.
Hopefully this time my request will be recognized.
Greetings
Michael from Germany
Offizielle Nachricht:
Rockethome Landing Page für Devolo Kunden:
Fully agree. Requested also a few times better support for Devolo devices. As you said nothing happened :-((
Hi!
I also have some smoke detectors from Devolo, requested the support of them two times. Really sad, that nothing happens here. :pensive_face:
Support for the humidity sensor would also be appreciated. But there are a few more devices with missing support in the devolo app.
Für devolo Wassermelder und devolo Sirene:
Flow anlegen nicht vergessen. Mit der “UND” Kachel kann man die unterschiedlichen Sounds wählen.
Den devolo Rauchmelder einfach als Z-Wave Gerät einbinden.
Der Flow sollte so aussehen: Wenn Rauchmelder eingeschaltet UND Rauchmelder ist an DANN mache irgendwas (Push Nachricht vielleicht?).
nachdem bei Homey pro in der develo app kein Wassermelder auszuwählen ist, habe ich diesen per Z-Wave Gerät installieren können. Der Wassermelder wird jedoch als “Steckdose” integriert! Der Flow: -wenn Wasser dann email - funktioniert zwar im Test. Bekommt der Wassermelder Wasser an die Fühler, piepst dieses aber über den Flow wird keine email abgesetzt.
Hat jemand eine Idee?
Warum nimmst du nicht die App, die von @Eichhorn, einen Post über deinem angeboten wird ?
Hi, sorry, aber eine App @Eichhorn (Geräte) bekomme ich bei Homey pro nicht.
Könntest du mir das schrittweise erklären.
Mfg.
Von meinem/meiner Galaxy gesendet
Ja, logisch, denn der Testknopf ersetzt die Triggerkarte (= "wenn"karte) :man_shrugging:
Du musst doch nur auf den Link klicken und die App installieren. Du hast dann zwei Devolo Apps, wobei diese App den Wassermelder hat.
Hatte das wohl falsch interpretiert!
Aber mit der @Eichhorn Anleitung geht’s auch nicht.
Gruss zi
Hallo Klaus,
es ist sehr wichtig, dass du den Wassermelder aus der MyDevolo App als neues Gerät einbindest. Dieser sollte dann auch als Wassermelder erkannt werden und nicht als Steckdose.
Klickst du nach dem Including auf den Wassermelder, dann sollten die Rückgabewerte Wasseralarm und Sabotagealarm zu sehen sein.
Jetzt erstelle den Flow: WENN “Der Wasseralarm ist angegangen” DANN Mail (oder ich habe hier Push Nachricht und devolo Sirenen Alarm eingetragen).
Durch die Abschaltung zu Jahresende war ich auch gezwungen auf ein anderes System zu wechseln. Homey Pro finde ich sehr geeignet. Ich konnte alle devolo Aktoren und Sensoren ins Homey Pro funktionsfähig einbinden. Nur das devolo Rollladenmodul kenn außer ganz offen und ganz zu noch keine Zwischenwerte.
Wenn es nicht funktioniert, dann beschreibe bitte genau die Stelle an der es nicht weiter geht.
Hallo Eichhorn
wenn ich ein neues Gerät in Homey Pro integriere, sollte ich ja über + Geräte die “MyDevolo” APP verwenden.
Ich habe jedoch nur die “Devolo” App zur Auswahl! Über suchen “MyDevolo” bekomme ich: keine Ergebnisse.
Wie kommt mam zur “MyDevolo” App?
Danke für Unterstützung
Kl
Guten Morgen Klaus,
bitte klicke hier unter dem Satz auf den blauen Schriftzug “MyDevolo | Homey”.
Dadurch solltest du auf folgende Seite gelangen:
Auf dieser Seite dann einfach rechts oben auf den grünen Knopf “Installieren” drücken. Und in dem kleinen Fenster welches sich danach öffnet, deine Homey Zentrale auswählen und wieder auf “Installieren” drücken. Dadurch sollte die MyDevolo App installiert werden.
Kurze Zeit später solltest du im Dashboard unter “+”, “ Neues Gerät”, “Deine Marken” die App “MyDevolo” finden. So die Theorie. An welcher Stelle geht es nicht weiter?
Hallo
besten Dank für die App. Nun funktionieren die Wassermelder!
Da ich ja Devolo zu Homey pro Umsteiger bin, und die Devolos, Philips Hues überall im Haus installiert sind, kommt noch einiges auf mich zu.
Ich denke, dass ich die Community noch öfters benötige.
Toll, dass es da Hilfe gibt!
Danke u. Grüsse. Zi
So, heute werden / wurden die Server abgeschaltet…
Ich bin gespannt wie die Integrationen von Homey und HomeAssistant sich die Tage verhalten…
Die “offizielle” Homey Devolo App von Athom scheint doch noch nicht tot zu sein. Denn am 05.01.26 wurden drei weitere Geräte hinzugefügt:
Deshalb meine Empfehlung an alle Devolo Umsteiger: Reicht Anfragen für Eure noch nicht unterstützten Devolo Z-Wave Geräte bei Athom ein.
Es geht wohl schneller wenn der passende Code für die fehlenden Geräte mitgeliefert wird.
Ich habe immer noch keine Kontrolle über die Sirene. Sie blinkt nur.
Weiß jemand schon, wie man den Sound macht?
Hi Aro,
trag den Parameter 7,1,128 in den Einstellungen ein und speichere diese
{54AD2768-10B0-4434-BDDB-98D3E5206920}
Dann kanst Du über die Flowkarten den Sound auswählen. Was leider nicht geht, ist kein Sound aber blinken.
