Hello, it seems to me that since the 12.3.0 update (in any case the problem appeared shortly after) I have strange bugs. I have tapo and wiz bulbs and tapo sensors and power outlets. All can be controlled individually by homey, the information seems to come back but some devices do not react when 1 flow is activated. These are the devices connected via the manufacturer’s application for wizz, for tapo only the tapo Hub is in matter with homey but some devices work, others do not. For example the bulbs work very well, the sockets do not. Result the motion detector is activated, only 1 wizz bulb lights up. If I turn it on manually via homey it works. I don’t understand anything because everything is OK before… Thank you in advance for your help
After a firmware update, weird issues often disappear after removing the power from Homey for 10 minutes.
Hello, thanks a lot for the solution, you are the Best ![]()
