Devices failing and getting more fails
I have a Homey Pro (Early 2019) currently running on version 13.2.4.
My problem I have had before, is that somehow I get a kind of deterioration of my system, which I do not know where it is coming from.
The latest example: I have the Sonoff App and 2 PIR’s on it. Suddenly my ligzhts do not switch off anymore, because the PIR is staying on person detected. When I investigate, put a new battery in, nothing changes. Resetting the device by re-adding it gives a failure to add device. Then I see the app has suddenly 0 devices on it and it does not allow me to add anything.
No idea what initiated the app to detach the devices (devices are still there but do not function) and how I can get this working again.
I have had similar issues before with the universal tuya zigbee app, that well defined devices are not allowed to be added, and apparantly this gets extended to more apps now. Before I let it go, as it was just new devices, that were there for a trial, but now it starts to affect my existing configuration and that is shitty to say the least..
Would appriciate any help I can get with this, as I am stuck and have no direction yet for a solution.
Have you tried restarting Homey?
Yes no effect with a restart of Homey and also not with a reinstall of the App.
Does an app have some data it is not deleting when the App is deleted?
